Water Cooled Raspberry Pi
If your Raspberry Pi is running a bit hot you can add a few hunks of salvaged heat sink, or you can go all out and machine your own water cooling system.
Remember when everyone had a giant desktop computer which was a perfect receptacle for cool lighting effects and somewhat ridiculous cooling systems? Relive that experience with [Phame’s] multi-page forum post that serves as the build log. With the exception of the tiny pump itself, this one’s a fully custom job.
The image on the left shows the machined parts being tried on for side. There is a slug which contacts the ICs on the RPi board, conducting the heat to the chambers inside through which the liquid will flow. The upright rectangular enclosure serves as the reservoir which dissipates the collected heat as the water flows through it. The image on the right shows the finished project. It uses the power pins on the GPIO header to drive the pump.
[Thanks PL via Bit-Tech]
25 thoughts on “Water Cooled Raspberry Pi
  1. If you’re going to do it, may as well over do it! Love the fact that he “roughed out” the channels with a 2mm end mill! A lot of milling would finish with a 2mm end mill.
  2. Hi, it says “The image on the left shows the finished project.”, but it should say “The image on the right”. Not trying to be a grammar nazi here, but it’s the only way I can help this site right now. Oh and nice build BTW, might be useful for extreme overclocking?
    1. Not sure how extreme you can get with overclocking as the critical part here doesn’t actually contact the CPU. The top of the RPi is the RAM chip, and the CPU sits under it with an airgap.
      That said this build is insane, it’s a work of art!
    1. Nah, a watercooled laptop would be like nitrous on a lawn mower.
      I think this is more like nitrous on a weed eater or maybe on a gas powered sidewalk edger.
  3. Overkill?!!? SO FSCKING WHAT?!?! THIS IS EPIC!!! By the way guys you NEVER need a reason to liquid-cool anything…why WOULDN’T you want this?!
  4. I love a good overkill in the morning!
    Still… why isn’t the fluid something fluorescent, illuminated with pulsating UV LEDs? With a mound of miniature skulls and skeletons in the fluid reservoir.
    Overkill should always be done right.
  5. When you have the machine tools, no project is to ridiculous to have an excuse to use them. I’d be more impressed if everything was orientated to create a thermosyphon eliminating the need for a pump.
  6. “Remember when everyone had a giant desktop computer”
    Yes. I also remember people predicting the end of the desktop PC, because all they ever did was internet and videos, so they couldn’t imagine why anyone would want a desktop. I was expecting a more realistic view from Hackaday.
Leave a Reply to barry99705Cancel reply
