Hackaday Links: Sunday, August 4th, 2013
hackaday-links-chain
[Craig Turner] shows that simplicity can be surprisingly interesting. He connected up different colors of blinking LEDs in a grid. There’s no controller, but the startup voltage differences between colors make for some neat patterns with zero effort.
Remember the 3D printed gun? How about a 3D printed rifle! [Thanks Anonymous via Reason]
While we’re on the topic of 3D printing, here’s a design to straighten out your filament.
It takes four really big propellers to get an ostrich off the ground. This quadcopter’s a bit too feathery for us, but we still couldn’t stop laughing.
This Kinect sign language translator looks pretty amazing. It puts the Kinect on a motorized gimbal so that it can better follow the signer. We just had a bit of trouble with translation since the sound and text are both in Hebrew. This probably should have been a standalone feature otherwise.
Work smarter, not harder with this internal combustion wheelbarrow. [via Adafruit]
13 thoughts on “Hackaday Links: Sunday, August 4th, 2013
    1. It’s bizarre, but I don’t have a problem with it. I wouldn’t mind if my corpse was used for a quadcopter. My remaining family might though.
  1. Mike Hi
    I have send you more info about the Kinect sign language translator to the TIPS e-mail.
    And I will add comments in english on the you tube clip later today.
    Thanks Amnon
  2. I don’t get the blinky LEDs “hack.” It’s just some blinking LEDs. Why is this impressive? The video describes a pattern. But I don’t see a pattern. Just a bunch of flashing LEDs that will sometimes line up, as flashing LEDs will do based on their variation in construction.
    1. That’s it exactly, the construction of the LEDs makes the pattern (different colors require different forward voltages and currents to work). It’s not random. Watch two LEDs or two colors for a while. But even that doesn’t matter – the brain will create patterns even for random sequences anyway. The pattern may drift after a while. But, I agree it’s not an impressive hack, just cheap and cheerful, pretty science.
  3. Inre: IC wheelbarrow
    The video doesn’t show it actually carrying a load. And it appears to only have engine braking and gravity to slow it down. This criticism is from someone who actually had to use a loaded wheelbarrow lately.
Leave a Reply to Mike SzczysCancel reply
