Hardware Freedom Day is tomorrow: Saturday, March 15th 2014. This is the third year for the event, which seeks to raise awareness about what Open Hardware is, and to encourage hackers and makers to share their own work with the world.
This is a concept that we believe in strongly here at Hackaday. There are a multitude of reasons to support open hardware. We usually look at it from two angles: education and user freedom. If the design for your projects are available, others can learn from your successes and produce even cooler things that in turn should be made open. At the same time, if you have a device that’s nearly-awesome, a skilled hacker will have a much easier time getting it there if the original design can be used as a reference.
If you want to see what’s going on near you there are events on every continent (except Antarctica… lame!). If continental adjacency isn’t close enough consider pulling together an adhoc event, or just going through that project you finished last year and publishing the files for others to use.
Nothing in Antarctica!? F**king penguins! (And you’ed think the little bastards would be all into open source!)
That logo is a fail. Those gears are drawn to not move.
It reminds me of this one from days of yore:
http://www.logodesignlove.com/department-of-innovation
But that is the great thing about things made open, I can use it and improve/fix it.
