Arduino Controlled Sewing Machine Increases Stitch Options
Arduino CNC Sewing Machine
[Andrew] is bringing his old mechanical sewing machine into the 21st century by adding an Arduino control module. Originally, his Alfa sewing machine could only do a straight stitch or a zig-zag of varying widths. Since this was an old sewing machine, all of the controls were knobs and levers. RC car servos were installed in the sewing machine and now are solely responsible for controlling, in real time, the horizontal movement of the needle and the amount of stroke of the feed dogs (the metal components responsible for advancing the fabric through the sewing machine). There is also a switch on the needle bar that feeds back to the Arduino when the needle is in the full-up position.
With full control of the stitch width and fabric advance, it is possible to come up with some awesome stitch patterns that were not possible on this machine before. Each of the stitch patterns are pre-programmed in the Arduino. Right now it is possible to control the sewing machine over the Arduino’s serial USB connection but the workflow for such an operation is in its infancy. [Andrew] plans on making this sewing machine fully automatic so that he can embroider letters and numbers.
Although the project is still a work in progress, [Andrew] has made his preliminary Arduino code available for folks who want to further his accomplishments. To continue reading about hacked sewing machines, check out this one converted to an embroidering machine.
23 thoughts on “Arduino Controlled Sewing Machine Increases Stitch Options
    1. There are videos floating around of CGI cutaways that make it pretty clear how they work, and it’s one of those things that’s so simple yet so unintuitive to just come up with. They’re really quite impressive machines.
      1. Check out a bread factory. They’re even less intuitive! So much trial and error must have gone into designing bread factory machinery.
    1. hint: thrift store (goodwill, acs, salvation army, habitat, etc…). cheap. very cheap. usually with their issues, but that’s a whole other learning experience for you, so two for the price of practically nothing!
  1. Next logical step is to sew soundwaves from wav loops stored on sd cards into the fabric so one very geeky dude can tace a photo and decypher the sound
  2. More and more newer machines (read: “Likely to be found on CL”) are electronic/programmable – is there any work being done to hack these since the motion control etc. would be in place and durable?
  3. I work in the commercial Cut & Sew industry. In a production setting we never use this type of machine, we use straight stitch machines, Or Overcasting/Overedging/Surging machines which are completely different (Chain Stitch Machines). If you want a programmable machine we use a Mitsubishi PLK’s or one of the equivalents or knock offs, If you want to do decorative stitching, you use an embroidery machine. If you really need to do a zig zag there are machines that just do that.
    On most commercial machines they use an optical encoder connected to the wheel, to detect needle position, Coupled with a HUGE stepper motor, but they are not really stepper motors. The industry calls them “Electronic Motors”, more like a electronically controlled conventional motor. They can control the position of the motor in a rotation, but unlike steppers, how many times they have gone around is not controlled. However, just to make things interesting, some manufactures are using stepper motors now. We use both of these for operations like Automatic Back Stitch, and Automatic Thread Cutting.
    I could see some use in hacking one of the electronic motors. You can control a lot of functions with those, the biggest being RPM, and position. But there are several other functions such as ramp, and automatic reverse (for back tacks). And they are “Cheap” about $200 on the used market.
  4. Now to encode secret messages in the stitching and driving certain people crazy as the spend the rest of their days ogling stitching
  5. You know what would be really cool? If there was a way to control a sewing machine from a video game!
    Oh, wait, nevermind.
    google search: “singer gameboy”
  6. There is a Secret Life of Machines episode on YouTube hosted by Tim Hunkin on how both mechanical & stepper motor sewing machines work
  7. Thanks for the information about sewing! I have wanted to learn how to sew for a long time now, and I am finally going to give it a shot. Thanks for the tip about getting plenty of sewing pins and a pin cushion. That will be the first thing I invest in!
Leave a Reply to TERRA OperativeCancel reply
