[M] recently tipped us off about hacker [Lumir Vanek]Â from the Czech Republic. Between 1985 and 1989, [Lumir] built his own home brew, Z80 based computer. The list of home computers available in the 1980’s is extensive. Those living in western Europe and the Americas could choose offerings from Acorn, Apple, Commodore, Atari, Radio Shack, and Sinclair Research to name just a few. Even the erstwhile Czechoslovakia had home computers available from Didaktik and Tesla.
[Lumir]’s built was based around the Z80 processor and is built using regular, double-sided, prototyping board. It featured the 8-bit Z80 processor CPU, 8kB EPROM with monitor and BASIC, two Z80 CTC timers, an 8255 parallel interface for keyboard and external connector, 64kB DRAM, and Video output in black & white, 40×25 characters, connected to a TV. The enclosure is completely made from copper clad laminate. [Lumir] documented the schematics, but there is no board layout – since the whole thing was discrete wired. He even built the membrane keyboard – describing it as “layers of cuprextit, gum, paper with painted keys and transparent film”. When he ran out of space on the main board, he built an expansion board. This had an 8251 serial interface for cassette deck, one 8-bit D/A converter, and an 8255 parallel port connected to the “one pin” BT100 printer.
On the software side, he wrote his own monitor program, which allowed simple interactions, such as displaying and modifying registers, memory, I/O ports and to run programs. He wrote this from scratch referring to the Z80 instruction set for help. Later he added a CP/M emulator. Since the Z80 had dual registers, one was used for user interaction, while the other was reserved to allow background printing. Eventually, he even managed to port BASIC to his system.
Check out [Martin Malý]’s awesome article Home Computers behind the Iron Curtain and the follow up article on Peripherals behind the Iron Curtain, where you can read more about the “one pin” BT100 printer.
That is flat out amazing.
Wow. Simply WOW.
This is one of the most impressive things I’ve seen in a long time.
My thoughts exactly, WOW.
It makes my adding a reset switch to my Timex Sinclair seem sad and pathetic.
That wire pr0n just made my day.
How do people do this stuff, it’s just amazing!
Fantastic!!!!
Anyone who can hand wire computer board and keyboard from scratch… just wow nothing but priase.
Someone should pair that Rum-80 with Trs-80 to see if it can produce trashed-160 ;)
Beautiful work. Amazing!
“Beautiful work. Amazing!” Odd… I thought the complete opposite.
It’s certainly not neat, but it’s quite an achievement. Let’s see you post a photo of your own much-neater hand-wired project, please. It would be instructional.
