Slack, Backwards Compatible With 1982
Slack is great, but there are a few small problems with the current implementations. There isn’t a client for Palm, there isn’t a client for the Newton, and there isn’t a client for the Commodore 64. The last of these severe oversights was recently fixed by [Jeff Harris]. He built a native Slack client in 6502 assembly for the Commodore 64.
When dealing with network applications and the C64, the first question that comes to mind is how to talk to the outside world. There are C64 NICs, and ESP dongles, but for this build [Jeff] turned to the C64 Userport. This card edge combination of a serial and parallel port allows the C64 to talk to anything with RS-232, and with a simple adapter, [Jeff] got his old computer talking to a Raspberry Pi connected to the Internet.
The C64 Slack client itself is written in 6502 assembly, and features everything you would expect. The Pi is required to talk to the Slack API, though, and uses a NodeJS app to translate the bits from the C64 to something the API can understand.
Does it work? Of course it does. Slack is just text, after all, and there doesn’t seem to be any PETSCII weirdness here. You can check out a video of the build in action below.
13 thoughts on “Slack, Backwards Compatible With 1982
      1. It’s taking an active part: the Pi is basically translating the Slack web API into a simpler RPC API that the C64 is talking. All the logic for how the API gets used is on the C64, though.
  1. I ‘never heard of slack before and I doubt I will ever be using it. But seeing it work on the C64 makes me feel good. I have made some devices for the CBM myself the past few years and it is always fun to see that others do to. So Thanks for sharing and keep up the good work.
    I was just wondering, is the device with an SD-card an SD2IEC? I assume you only use it to load you stack-client program into the C64 and the the client itself does not require it.
    1. It is a little more clever than “just” a dumb terminal… the protocol seems to be actually designed for passable performance over this slow of a serial link.
      Would using SLIP or PPP count as enough more real?
Leave a Reply to FRANCK GALLIATCancel reply
