Clever Battery Holder Hack Makes Brilliant Earrings
A ‘googly eye’ with hole for LED leads on one side, slot for coin cell on the other. Black disk for pupil removed.
We love seeing a thing get used effectively for other than its intended purpose, and this DIY LED Earrings project is a great example. [IdunnGoddess] liked the idea of making light-up LED earrings powered by a small coin cell, but an enclosure and power connection for the battery were sticking points. The solution? A googly eye after a few minor modifications turned out to be perfect.
A googly eye resembles a thin, flat, hollow plastic bulb. Choose one that’s just a bit bigger than the coin cell, and cut a slot in one end and a small hole in the other. The LED leads go into the hole, and the coin cell slides into the slot. The result? A lightweight battery holder for an attached LED, and as a bonus the hacked googly eye is a clean and super smooth surface that can easily be painted or decorated to make it part of the design. The video embedded below demonstrates the process and showcases a few sample designs.
Most LED-lit fashion accessories (like these LED Matrix Pendants) are forced to treat the battery like a necessary evil, a kind of mild embarrassment to be hidden away. It’s refreshing to see a solution that not only does away with extra parts, but allows the battery enclosure to be incorporated as part of the design. It’s a wonderful use of a part in an unusual and effective way.
[via Solarbotics Blog]
6 thoughts on “Clever Battery Holder Hack Makes Brilliant Earrings
  1. This is a brilliant hack! Using what you have on hand to get the job done. Time to add a pair of cuticle scissors to the tool kit.
Leave a Reply to Peter MisenkoCancel reply
