Teletype Machine Resurrected
A teleprinter is, at its heart, an automatic typewriter.  It’s electrically controlled and has some smarts to be able to decode an incoming message and has something that will move the keys.   These printers have been in use since the late 1800’s and [AethericLtd] have refurbished an old 1930’s design and given it a bit of steampunk flair.
As is common with older mechanical devices that have been sitting for extended periods of time, the first thing this machine needed was a bath. The machine was separated into its three main parts and soaked in a degreasing solvent. The keyboard was the dirtiest, so it got an overnight soak. Since little of the mechanism was electrical, most of it could be submerged which helped with the cleaning.
The next step in the restoration was lubrication. In order to do a proper job, the manuals (which were available online) were consulted and synthetic motor oil used for lubrication. Once all the hundreds of parts were oiled, [AethericLtd] started working on the wiring. The original wiring in this machine was called Deltabeston – a type of wire by General Electric which uses asbestos insulation. To play it safe, that wire was left alone. The selector magnet required only 4 volts to pull up, but 4 volts wasn’t enough to run the machine. The power supply used was a 120 VDC, 200 mA supply through a 2 KΩ, 10 W resistor.
Once everything was back together and working, [AethericLtd] could take machine out and show it off. The website describes not only the restoration process but also the setup, how to connect to the machine and how to communicate with the machine. Great work! If you are interested in these machines, there have been a few Teleprinter projects on the site before: this one has been modified to connect to a modern modem, and this one prints out tweets.
10 thoughts on “Teletype Machine Resurrected
  1. Deltabeston, wow. Kinda like Raybestos for brakes.
    It could be coated with a number of coatings which should help protect it and keep it from ablating.
    Think liquids that soak in.
  2. Wonderful machines!
    I had a model 15 teleprinter and for some reason I can’t recall, years ago I gave it away, along with my vintage computer collection and the first amplifier I ever built. Regretted it all ever since.
    The teleprinters are a great device to watch working. I used mine in ham radio and as the printer for my Signetics 2650 computer. I wish I still had the teleprinter :(
    1. I was just thing about the 2 model 33’s I used to have sitting in my bedroom when I was in high school should never have turfed them either :(
  3. I just picked up a Model 15 (and an ASR33!) last weekend and have already spent hours just gazing at it’s innards. They’re essentially mechanical shift registers; absolutely mesmerizing and beautiful mechanisms.
    I had a choice between that and a model 28, but the M15’s mechanism seemed a little more straightforward from a maintenance and troubleshooting standpoint. I actually stumbled on this page when researching which one to take, and am really happy with what I got – just one gear away from getting it up and running.
  4. I don’t get the part “and has something that will move the keys” – There is nothing that will move the keys – this is not a player piano. The keyboard (transmitter) and printer (receiver) is seperate parts. (I have 5 Teletypes in my collection, so i know the ins and outs of them)
  5. I’m amused to see this on here, since I’m the person who built this. I had nothing to do with this article. We first did a steampunk telegraph office in 2010, at the Nova Albion steampunk convention, and we’ve done it at conventions every year or so since.
  6. Hello,
    I have a Model 15 teleprinter that came from a radio station. I am trying to build a studio from the 60’s Who can I contact to refurb my teleprinter? Thanks and God Bless Fred
