Around the Hackaday secret bunker, we’ve been talking quite a bit about machine learning and neural networks. There’s been a lot of renewed interest in the topic recently because of the success of TensorFlow. If you are adept at Python and remember your high school algebra, you might enjoy [Oliver Holloway’s] tutorial on getting started with Tensorflow in Python.
[Oliver] gives links on how to do the setup with notes on Python versions. Then he shows some basic setup operations. From there, he has the software “learn” how to classify random points that either fall into a circle or don’t. Granted, this is easy enough to do with traditional programming, so it isn’t a great practical example, but it is illustrative for learning purposes.
Given that it is easy to algorithmically decide which points are in the circle and which are not, it is simple to develop training data. It is also easy to look at the result and see how close it is to the actual circle. You’ll see that it takes a lot of slow learning before the result space looks like a circle and not a triangle or some other odd shape.
