Hackaday At 34C3
It’s that time of year. While the rest of the Christmas-celebrating world sits around and plays with the toys that they got out from under the tree, German nerds head off to the biggest European hacker con: the 34th annual Chaos Communications Congress, running Dec. 27th through 30th.
The CCC is both a grandparent among hacker cons, and the most focused on using technology to improve the world and bringing folks together. (The “communications” in the name is a dead giveaway.) This year’s motto, “tuwat!” is slangy-dialecty for “do something!” and is call to get up off the couch and use your super-powers for good.
If you can’t get over to Leipzig to join us, you’ll be able to read our extensive coverage starting up shortly after the opening ceremonies, and probably stretching well into 2018. And since the CCC media folks manage to stream every talk, hackers all over the world can follow along live. Most talks are in English, so get together with folks in your hackspace and have a video night!
And if you are in Leipzig, be on the lookout for [Elliot] who will be wandering around, attending workshops, and writing down as much as possible. Show me something cool, rave about a particularly good talk, or just say “hi”.
Fairy Dust clipart courtesy [sonoftroll].
19 thoughts on “Hackaday At 34C3
        1. Close. It’s the german “sharp” W, somewhere between forming an “ooh” and an “f”. “Was wir wollen”. Listen and repeat.
          It could also be stated as “Sabbel nich, mach!”.
Leave a Reply to Elliot Williams Cancel reply
