[Daniel L]’s friend has a passion for Warhammer 40K. [Daniel] himself has a similar zeal for perfection in details. When he remembered a long-forgotten request to build a working rocket launcher for one of his friend’s Warhammer 40K models — well — the result was inevitably awesome.
The MicroMaxx motors — one of the smallest commercial rocket motors on the market — he had on hand seemed to fit the model of the Hyperios Whirlwind anti-air rocket tank. Modeling and 3D printing all the parts proved to be easier than assembling the incredibly detailed model — on top of sanding and filling gaps, a perfect paint job was no simple matter.
The launcher has two main circuit boards: a STM32F407 microcontroller brain, a low-power A20737A Bluetooth module, and a voltage regulator. The second has the constant current source and MOSFET output stages for the rocket igniters. Pitch and yaw handled by a pair of RC servo motors. [Daniel L] has also gone the extra mile by creating an accompanying iPhone app using the Anaren Atmosphere IDE — it’s simple but it works!
While you may be tempted to fire off a full-salvo, keep this in mind: each rocket is a custom-made, single-use projectile. Milled out of plastic tubing with stability cuts made in the side and a 3D printed, sanded, and painted nose cone, every one is a labour of love!
For your not-quite-40K model rocket hobby, make your next launch count with a bit of guidance.
Lovely job! But, eh, firing rockets indoors? Safety nannies gonna get you!
Sorry…. but I misread that as safety nanites.
This little rockets can be fired indoor if you are careful. Ok, the launch you can see in the video destroyed the window at the end of the corridor ;-)
No need to custom make projectiles. Those cakes with sseveral hundred shots contain these premade on strings.
Separating them is probably far more efficient than making them.
Deja Vu all over again..
I was forced to babysit my bosses two teen boys at the hotel..
Those little effers started shooting bottle rockets down the hall at night..
Cops were not amused..
