[Andrew MacPherson] found out that compliments, even insincere ones, make the recipients feel better. So, he put together a thermal printer and a hilariously large button with an Arduino and created a machine that prints compliments. And where best to put a machine that prints out compliments? The local bar, where else?
An Arduino Nano clone runs the show connected to a thermal printer. The Nano clone didn’t like the 9 volt power supply, so a buck converter was used to reduce the voltage down to 5 volts for the Nano, while the printer gets the full power. During initial trials, the printer was very slow to print and it took [Andrew] a while to adjust the parameters – after tweaking the speed as well as the heating time, he was able to get the printer working without burning the paper or taking forever to print.
Once the machine was working, it was time to add a button. A large, light-up button was connected and glued to the side of the printer. More glue was used (after some “modifications” to the printer chassis) to secure a barrel connector for the power adapter.
[Andrew] decided that since he’s down at his favorite bar quite a lot, he’d set it up there. The customers could push the button and receive a compliment while drowning their sorrows. He got a friend of his who’s a copywriter to come up with some nicely written compliments to print out. The printer was such a hit that the bartender sent [Andrew] a message on Facebook saying so. If you have a thermal printer lying around, you can use this tutorial to connect it to the internet, or, if you don’t have one, you can build your own.
Needs an algorithm that slurs the compliments more for each drink drank…
Randomly, with a probability of about 1/100 or so it should chose from a list of insults instead.
Or cheap pickup lines.
Oh no. That’s reserved for a dedicated machine located in the men’s room. That one takes quarters!
A couple of similar machines in the ladies room give out excuses and fake phone numbers.
Nice!
Remembers me the “Fortune Box” https://www.robotshop.com/letsmakerobots/fortune-box
and the “Dadaist box”!
Like it!
Now for a portable versions for travel that throws out insult.
