Occasionally we come across a piece of information which reminds us that, while flying cars are still nowhere to be found, we’re definitely living in the future. Usually it’s about some new application of artificial intelligence, or maybe another success in the rapidly developing field of private spaceflight. But sometimes it’s when you look at a website and say to yourself: “Oh cool, they have 1.5kW electromagnetic accelerators in stock.”
Arcflash Labs, a partnership between [David Wirth] and [Jason Murray], have put their EMG-01A Gauss gun up for sale for anyone who’s brave enough and willing to put down $1,000 USD on what’s essentially a high-tech BB gun. The creators claim it obtains an efficiency of 6.5% out of its RC-style 6S LiPo battery pack, which allows it to fire over 100 rounds before needing to be recharged. Firing 4.6g steel projectiles at a rather leisurely 45 m/s, this futuristic weapon would be more of a match for tin cans than invading alien forces, but at least you’ll be blasting those cans from a position of supreme technical superiority.
The EMG-01A builds on the work of the team’s previous experiments, such as the semi-automatic railgun we covered last year. They’ve made the device much smaller and lighter than their previous guns, as well as worked on making them safer and more reliable. That said, the page for the EMG-01A has a number of warnings and caveats that you won’t see on the back of a Red Ryder BB gun box; it’s certainly not a toy, and anyone who takes ownership of one needs to be respectful of the responsibility they’re taking on.
Speaking of which, who can actually buy one of these things? The Arcflash Labs site makes it clear they will only ship to the United States, and further gives a list of states and cities were they can’t send a completed gun. Essentially they are following the same laws and guidelines used for shipping air guns within the US, as they believe that’s a fair classification for their electromagnetic guns. Whether or not the ATF feels the same way is unclear, and it should be interesting to see what kind of legal response there may be if Arcflash Labs starts moving enough units.
If you’d like to wage warfare on your recyclables without spending quite so much cash, you can always build your own for less. Or nearly nothing, if you want to go the full MacGyver route.
Muzzle velocity 45 m/s
Muzzle energy 4.65J
Efficiency 6.5%
Any air gun will do more.
Yeah, just under 150 fps? That’s not even enough to reliably punch holes in paper at a 10 meter airgun range. Typical airgun speeds are about 400 fps. For reference, the speed of sound at sea level is about 1123 fps.
In other words, it’s not good for much.
I’m pretty sure even in the US sound would prefer travelling in meters per second…
And I think you wanted to say 32,8084 feet airgun range right? Or is this your brain, desperately trying to switch to metric? ;-)
Nope, here in the US sound always travels in miles per hour. It’s a contractual thing. :D
B^)
Yep! Thunder travels at 3 seconds per mile!
Um actually sound in the USA takes 3 seconds per kilometer. 5 seconds per mile (ish).
Feet per second is also permitted.
He said 32,8084 fps 🤣 as he insulted ur intelligence
We are still half switched to metric in the US. It’s a standards stalemate since the 70s.
I’d be happy if they just ditch the m/d/y date format and go to either y/m/d or d/m/y.
That’s because here in the states we still haven’t understood how much easier base tan is for measurement
The international standard for air gun ranges is 10m. Just like a drag strip is 1/4 mile (or 1/8 mile, or 1000 feet) everywhere in the world. Here in Europe, everything is metric, yet we still use convenience units for certain things:
Most people will discuss compare car horsepower (even if it’s just because the numbers are slightly bigger than when using kW), and for food we use calories rather than joules.
You can always convert them when needed, e.g. when used in formulas where other units play a factor.
Note that from europe, “FPS” sounds like “frames per second”…
FYI, velocities for firearms and airguns sold in the US are usually stated in fps. However, the standard for indoor competition airgun ranges is 10 meters. That’s just how it is.
I have not tried this myself but I am willing to wager that a 4.6 gram slug traveling at 150 fpa will reliably put a hole in the target or rip the target off the retaining clips. Would probably do the same if the target were made of cardboard. A smaller pellet might have problems at that speed but the heavier projectile would prove harder to stop for the paper target.
So if you have 1123 frames per second your graphics card has reached mach 1? :-)
It’s about kinetic energy, not necessarily just speed.
I sincerely hope if were ever attacked by aliens this is their weaponry as it stands now……
Yes. But these firearms look to the Future. Think of vintage bag-phones then think of smart- phones today. BTW, recently I saw a DIY plasma rifle punch a 1.5 cm hole in a 2.5 cm cold-hammer forged stainless steel plate at 20 meters. Is this the kind of “stopping power” you want ?
i probably could throw the pellet (or the gun for that matter) at higher speeds and kinetic energy…
I wonder how much extra energy could be achieved with an active projectile. Basically 2+ coils of wire, high current switches. a processor and battery as the actual projectile. And there is also the possibly of two way communication between the projectile and gun, right up until it leaves the accelerator, using using the magnetic field
Or even IR LED’ :)
Use air to deal with inertia. Gauss once it get’s going. Detecting transition point could be in the coil since ammo is metal.
Inertia does not disappear when it start moving. Inertia is a consequence of mass.
And now you are dragging part of the power source along.
Why not have the projectile load into a centrifuge and once up to speed, initiate the magnet sequence? If you get it precise enough, you could load 2, 4, even 6 rounds into the centrifuge and do them back to back as they come around and align with the “barrel”.
Nice
If you’re still winding coils and using electrolytics capacitor, I’m not impressed.
“essentially a high-tech BB gun”
Without watching the video, does it use BB’s (.17 caliber) or special ammo?
Not without watching the video it doesn’t
B^)
It uses these as ammo:
https://arcflashlabs.com/product/2575-magnetic-armature-alloy-steel/
Thanks!
$0.42 each! Before tax and shipping…
.22 rounds are cheaper :oP
I can reload full power 308 for cheaper!
it’s going to be a while before we can use electricity as the propellant in any meaningful way
Arcflash Labs ≠ Archlabs
Wait ’till we have pocket sized stellarators and room temperature superconductors.
Take this, ugly aliens!
Pacem Propter Voltage
Peace Because of Voltage, or
Peace Through Voltage, if you like.
Peace on Earth
Purity of Essence
(Dr. Strangelove reference)
peace through power?
https://youtu.be/zFUfF3Ws39E
And like the deadly Red Ryder, it’s a firearm in NJ
How can it be a firearm, if it does not use any form of combustion?
They’re still using the coilgun principle, which has a tradeoff between velocity and efficiency because at higher accelerations the projectile becomes magnetically saturated and further increases in coil current give diminishing returns.
Hence the low muzzle velocity.
A switch to an active projectile made out of non-magnetic materials (linear induction motor instead of linear reluctance motor) would do the trick, but designing them is more difficult because the electronics become more complicated.
It’s power can only be contained by the mighty old towel backdrop.
B^)
Now if only this can accelerate, and induce a spin on a projectile it would remove the need for a rifled barrel, reducing friction. Would also be nice if the magazines come with the capacitors, so that changing the mag also replaces the used up capacitor with a pre-charged one.
“Firing 4.6g steel projectiles at a rather leisurely 45 m/s”
Firearms projectiles are weighed in grains, in the US and elsewhere. 4.6 grams is about 71 grains.
My AR-15s (note the plural) can put a 68-grain projectile downrange at velocities in excess of 3000fps (914 m/s). Let’s assume the two projectiles are the same weight, which they nearly are. Then, the muzzle energy on an AR-15 is 914^2/45^2 = approximately 412 times greater.
But I think Gauss guns will get there, eventually. Need to go to AC induction, as an earlier poster indicated.
Also, I wonder if electromagnetic induction couldn’t be used as a second stage, to boost the velocity of a chemically-propelled projectile.
Yes but then one have the problems of chemical propellants added to the problems of EM propulsion.
Would make more sense to use a ETC (Electro Thermal Chemical) design to spice up the chemical design, improve the combustion using an electrical plasma discharge.
Yes, the US use many strange units of measurement and they even try coerce people outside of them to their units. When I was a child, TVs were measured in cm, now, with computer monitors everywhere inches appear. Big thumbs down! I can imagine, what 4,6g is, but not what grains are used for measurement. millet? wheat? corn?
Of course this gun is an (expensive) joke, but that is no excuse to promote ancient units of measurement.
When were TVs measured in cm? I’ve literally never seen that. And I worked on TVs since the ’80s.
The problem with the metric system is that it was invented by the French. “Everyting muss be en base 10 n’est pas?”
So every measurement the French used they converted to base 10 and forced the system on all the Europeans. Mileage, velocity, weight, volume, distance, and temperature are all base 10. The French are a simplistic people who basically make wine, cheese and clothing. It’s a shame we let them change the Imperial system the Romans devised that everyone understood for 2500 years.
Fail, using magnetic projectiles. You need non-ferrous metals. Military and commercial use an aluminum or copper sabot.
The problem with ferrous is that you are relying on the magnetic field of the coil to attract the projectile. But first, the eddy currents that build up in the projectile act to repel, then only as the eddy current dies down can the coil attract the projectile.
But then as it leaves the coil, the magnetic field is pulling it back into the coil. When you collapse the field, the change in field induces another eddy current that again retards the forward motion of the projectile. Lenz’s law, the eddy current flows in the direction that creates a magnetic field that opposes that change in magnetic field that created it.
As was pointed out above, also, with a ferrous projectile, you reach saturation of the projectile, limiting acceleration.
Eddy currents also waste energy as heat.
You might try using, oh, I don’t know, a lead projectile in a sort of copper, shall we say jacket? That doesn’t seem difficult to find.
Then you are relying only on the repelling of magnetic fields. The faster the change, the better as it gives less time for the eddy currents to die down and stop pushing.
Dammit, I don’t have enough free time/money! I need to win several hundred million in the lottery.
Steel projectiles experience minimal eddy currents because the skin effect in magnetic materials is very strong.
The skin effect is a problem for induction guns as well, which is why the military is intersted in proper gauss guns which operate on the Lenz law: there’s a DC current going sideways through the projectile, while the rails induce a vertical “static” magnetic field, which causes a force at right angles to the current and the field, i.e. along the barrel.
You still have the other issues.
That would be a rail gun, then. I try not to mix the terms so as to avoid misunderstandings.
A Gauss gun is a generic term for magnetic accelerators, but it originally meant an arrangement of permanent magnets (a science toy) where the static magnetic field would provide the acceleration when the arrangement is tipped past its balance point, releasing the stored potential energy from when the magnets were arranged.
For some reason, people started to claim the term to mean a coilgun which is just a solenoid without a backstop. A railgun on the other hand is more of a “pure” Gauss gun because the magnetic field is “static” much like in the science toy. There’s no switching of currents going on, except for when you turn it on, and when the projectile leaves the rails.
I’m just sticking my foot in it all over the place.
I was somehow thinking of “coilgun” whenever I read “gauss gun”.
I meant to say, good point about the skin effect being much less deep on ferrous metals.
That would be an argument for highly conductive projectiles in an asynchronous motor like configuration.
“practical”
Has anyone ever tried to build a gun using whatever tech allows some of those roller-coasters to launch really fast (which I believe is in turn a higher speed variant of whatever allows maglev trains to work)
I think this is a linear synchronous motor. Requires strong (expensive) magnets as projectiles.
The United States Navy has a patent (https://patents.google.com/patent/US7444919) on such a gun.
Have they actually tried to build one using the technology described in that patent? I’m not sure, but they definitely have worked on railguns.
My bet is that the muzzle velocity is not due to coilgun limitations, but a legal safeguard to stay in the BB-gun ballpark and avoid all the “proper firearm regarding muzzle energy” hassle.
What if we back one of these with a airgun mechanism the vaccum behind the shell will be negated. May need to await graphene.
No such thing as vacuume.
