CNC machines are powerful tools when used correctly, but it’s often necessary to test a new machine before getting into serious production work. This advent calendar is a great festive project that was designed to put a CNC through its paces.
The calendar is made primarily from wood. This is an excellent choice for test machining projects, as it is softer and less likely to cause tool or machine damage when compared to steel or aluminum. The calendar base was first milled out using end mills, while a 30-degree V-bit was used to engrave the days of the week. Brass brazing rod was then used to create hangers for the calendar tags.
Thanks to the clever use of chalkboard paint and removable tags, the calendar can be reconfigured to work for any given year and month combination — just in case you wish to have an advent calendar year round. Overall, it’s a good low-intensity machining project that would also be a fun craft project for kids.
As it’s that time of year, you might like this blinky advent calendar, too. Video after the break.
[Thanks to Michael for the tip!]
Did anybody else spot the missing date on the left calendar right away? What happened to Christmas Eve?
Hint: apparently, only the main blog page shows the two calendars side by side..
Easest way to mount those supported round shafts yes, but also the weakest considering typical forces in a CNC machine, see polar graph on page 61 here https://www.thomsonlinear.com/downloads/bearings_guides/RoundRail_LinearGuides_Components_cten.pdf
