Talking With Bubbles
Despite the title, this isn’t a tale of conversing with Michael Jackson’s chimp. Rather, it is about [KyungYun]’s machine that transforms speech into whimsical bubbles. While the speech control is novel, we were more fascinated with how the mechanism uses a system of strings to blow bubbles, along with the workmanship to make the device portable.
The rate of fire isn’t that great, so the bubbles appear to simply get larger the longer you talk. Essentially, the device increases the size of the iris — the part that blows the bubble — until you pause speaking. Then it burps out a bubble.
The iris mechanism has borrowed ideas from a much larger bubble machine, though the actual build is much smaller and uses both laser-cut and 3D printed pieces. A Teensy provides the brain, and there’s a pump for transferring bubble solution into the iris.
As best we can tell, soapy liquid drips down the strings which are touching. When the strings separate, it forms a soap film between them. A burst of air, then, can produce a bubble. It is possible to make colored bubble solution and we were trying to think of a way to make different colors for different kinds of sounds, although, having three iris mechanism would make the device much less portable. Perhaps it would be more practical to have multiple tanks of the solution and mix them differently based on sound analysis. In any event, this would be a fun project to extend with some creative additions.
We’ve seen more than one approach to blowing bubbles. If you want lots of bubbles, you might 3D print this contraption.
3 thoughts on “Talking With Bubbles
  1. I like the project where a space of 10’s of square feet is opened up by the soapy strings and a wall of bubble bulges into the 2 or 3 story space indoors. Blown away.
    Since I am often listening to music I watch YouTube’s offerings but listening is optional because of the often weak audio levels. I couldn’t get any animation out of the demo. Just on off times. Enveloped audio?
  2. You know, in the Yukon it gets so cold that when people yell, the sound freeze and drops in the the snow. In the spring thaw it can get pretty noisy on a warm.
Leave a Reply to echodeltaCancel reply
