Understanding Modulated RF With [W2AEW]
There was a time — not long ago — when radio and even wired communications depended solely upon Morse code with OOK (on off keying). Modulating RF signals led to practical commercial radio stations and even modern cell phones. Although there are many ways to modulate an RF carrier with voice AM or amplitude modulation is the oldest method. A recent video from [W2AEW] shows how this works and also how AM can be made more efficient by stripping the carrier and one sideband using SSB or single sideband modulation. You can see the video, below.
As is typical of a [W2AEW] video, there’s more than just theory. An Icom transmitter provides signals in the 40 meter band to demonstrate the real world case. There’s discussion about how to measure peak envelope power (PEP) and comparison to average power and other measurements, as well.
Although the examples use a ham radio band, the concepts will apply to any radio frequency from DC to light. If you want to do similar measurements, you’d need a scope, a peak-reading watt meter, and a dummy load along with the transmitter.
We enjoyed that he uses a scope probe as a pointer, but we can’t really explain why. If you are ambitious, you can build your own SSB transceiver. Another common way to modulate RF is FM and we’ve talked about it before, too.
10 thoughts on “Understanding Modulated RF With [W2AEW]
  1. Good one. Next time somebody shows me an SSB-signal on a scope and tells me “the upper part is USB, the lower past is LSB”, I will say no word and just show them the video.
    1. Who would look at a scope and even consider that they could see side bands as they are a frequency domain thing?
      If you look on a spectrum analyser you see the upper and lower but not in the time domain and having watched the video I didn’t see what you were referring to.
  2. I barely delve in to broadcast engineering stuff, but somehow have been the only person who has known about digital over shortwave standards in conversations for years..
    I had a modem for it three years ago and it’s near impossible to get boards or chips for it even now..
  3. There was a course, Signals and Systems, IIRC, when I was an undergraduate. It derived all the standard modulation schemes from their mathematical equations. It was one of the courses I enjoyed the most.
    SSB is easy to generate if you just go out and buy that little Hilbert Transformer :-)
Leave a Reply to problemchild68Cancel reply
