Now That’s What I Call Crypto: 10 Years Of The Best Of Bitcoin
On January 3rd, 2009, the Genesis Block was created. This was the first entry on the Bitcoin blockchain. Because of the nature of Bitcoin, all transactions lead back to this block. This is where Bitcoin began, almost exactly ten years ago.
The Genesis Block was created by Satoshi, a person or persons we know nothing about. In the decade since, we’ve seen the astonishing rise and meteoric descent of Bitcoin, and then it happened again after the bubble was re-inflated.
Due to the nature of Bitcoins, blockchains, and ledgers, the entire history of Bitcoin has been recorded. Every coin spent and every satoshi scrupled has been recorded for all to see. It’s time for a retrospective, and not just because I wanted to see some art based on the covers of Now That’s What I Call Music albums. No, ten years is a lot of stories to tell.
Continue reading “Now That’s What I Call Crypto: 10 Years Of The Best Of Bitcoin”
Under The Hood Of Leica Camera Firmware
There’s nothing quite like waiting for something you’ve ordered online to arrive. In [Alex]’s case, he’d ordered a new Leica camera, only to find out there was a six month backlog in shipping. Wanting to whet his thirst regardless, he decided to investigate the Leica website, and reverse engineered a whole heap of camera firmware. As you do.
[Alex] didn’t stop at just one camera, instead spreading his interest across whatever firmware Leica happened to have online at the time. This approach led to improved effectiveness, as there were similarities in the firmware used between different cameras that made it easier to understand what was going on.
There are plenty of surprise quirks – from firmwares using the Doom WAD data format, to compression methods used by iD software in old game releases. [Alex]’s work runs the gamut from plotting out GUI icons on graph paper, to building custom tools to tease apart the operation of the code. Sample components were even sourced from connector manufacturers to reverse engineer various accessories, too.
[Alex]’s methodical approach and perseverance pays off, and it’s always interesting to get a look under the hood of the software underpinning consumer devices. We’ve even seen similar work done to decode the mysteries of Pokemon cries.
[Thanks to JRD for the tip!]
Adventures In Power Outage Hacking
The best type of power outage is no power outage, but they will inevitably happen. When they do, a hacker with a house full of stuff and a head full of ideas is often the person of the hour. Or the day, or perhaps the week, should the outage last long past the fun little adventure phase and become a nuisance or even an outright emergency.
Such was the position that [FFcossag] found himself in at the beginning of January, when a freak storm knocked out power to his community on a remote island in the middle of the Baltic Sea. [FFcossag] documented his attempts to survive the eight-day outage in vlog form, and although each entry is fairly long, there’s a lot to be learned from his ordeal. His main asset was a wood cook stove in the basement of the house, which served as his heat source. He used a car radiator and a small water pump to get some heat upstairs – a battery bank provided the power for that, at least for a while. The system evolved over the outage and became surprisingly good at keeping the upstairs warm.
The power eventually came back on, but to add insult to injury, almost as soon as it did, the ground-source heat pump in the house went on the fritz. A little sleuthing revealed an open power resistor in the heat pump control panel, but without a replacement on hand, [FFcossag] improvised. Parts from a 30-year-old TV transmitter were close at hand, including a nice handful of power resistors. A small parallel network gave the correct value and the heat pump came back online.
All in all, it was a long, cold week for [FFcossag], but he probably fared better than his neighbors. Want to be as prepared for your next outage? Check out [Jenny]’s comprehensive guide.
Continue reading “Adventures In Power Outage Hacking”
