Voice Chess Uses Phone, Arduino, And An Electromagnet
[Diyguypt] may be an altruist to provide the means for people who can’t manipulate chess pieces to play the game. Or he may just have his hands too busy with food and drink to play. Either way, his voice command chessboard appears to work, although it has a lot of moving parts both figuratively and literally. You can check out the video below to see how it works.
The speech part is handled by an Android phone and uses Google’s voice services, so if you don’t want Google listening to your latest opening gambit, you’ll want to pass this one up. The phone uses an app that talks to the Arduino via Bluetooth, which means the Arduino needs a Bluetooth module.
The Arduino controls what amounts to an upside-down 3D printer. Instead of a hot end pointing down, the mechanism has an electromagnet pointing up. A small washer in the base of each chess piece makes it susceptible to the magnet’s motion. The electromagnet is required to let go of a piece before a move to a new position. It is possible that a small servo moving a permanent magnet closer to the board for a move and away from the board to reposition could do the same job, though we suspect that could be tricky.
We’ve seen this before, often with a Harry Potter theme. We sort of prefer a more obvious chess robot, but that’s just us.
6 thoughts on “Voice Chess Uses Phone, Arduino, And An Electromagnet”
  1. “If you don´t like our planet and want to contribute to the deforestation, buy some wood and make a nice design to the board. ” (In the build description)
    -LOL.
    This right after suggesting getting 2-3 bluetooth modules in case they burn out.
    As if Aluminum and electronics and shipping and voice recognition had no environmental impact.
