Ondophone On Point
The name Ondophone is a mash-up of two instruments, the Marxophone, and the ondes martenot. From the Marxophone, [Wintergatan] borrows the spring-loaded hammers, which repeatedly strike a string once activated. The ondes martenot loans its Theremin-like sound and ability to lean back on western semi-tone notes. Mating such different instruments requires a team, and much like the name, it produces a splendid blend.
At the left-hand side of the Ondophone, we see the spring-hammer battering away on a steel string whenever the neck moves up or down. Next to it is an Ebow that vibrates a string with an electromagnet and can maintain a note so long as it has power. Hidden within the neck are magnets to demarcate semi-tone locations, so it’s possible to breeze past them for a slide sound or rest on them to follow a tune.
The combination of intermittent hammering and droning lends well to the “creepy” phase of the song, which leads segues to the scope-creep that almost kept this prototype on the drawing board. The video talks about all the things that could have been done with this design, which is a pain/freedom we know well. KISS that Ondophone headline act goodbye.
The ondes martenot is an early electronic instrument, so we’ve some high-tech iterations, and if you haven’t heard what’s possible with a DIY Ebow, we will harp on you.
5 thoughts on “Ondophone On Point
  1. I built the “e-bow” concept into the steel guitar and the volume control into the steel bar. Those old Yamaha electone organs with the lever pots make a better volume control than the older Baldwin pressure controls that I was using. No detents or marks just listen and play like any string in the orchestra. The detents mess with vibrato and bends. Wrapped up with Digitech FX power and speaker, it’s portable Pink Floyd.
Leave a Reply to echodeltaCancel reply
