A Rocket Powered Ejection Seat For Model Aircraft
As radio control planes don’t typically have human pilots onboard, the idea of installing an ejection seat in one is somewhat frivolous. But that doesn’t mean it wouldn’t be a lot of fun, and [James Whomsley] has set his mind to achieving the task.
The build process is an iterative one, with [James] solving problems step-by-step and testing along the way. The first task was to successfully launch a small action figure and his flight seat vertically in a controlled fashion. After a few attempts, a combination of rocket motors and guide rails were settled upon that could achieve the goal. Next up, a drogue parachute system was designed and tested to stabilize the seat at the height of its trajectory. Further work to come involves handling seat separation and getting the action figure safely back to the ground.
While action figures aren’t alive and the ejection seat serves no real emergency purpose, we can imagine it would be a hit at the local flying field – assuming the parachutes don’t get tangled in someone else’s model. For those interested in the real technology, our own [Dan Maloney] did a great piece on the topic. Video after the break.
4 thoughts on “A Rocket Powered Ejection Seat For Model Aircraft
  1. While I’m sure the intent here is benign, I can’t help but wonder if pyrotechnically launching something from a small UAS falls afoul of some law or regulation.
    I vaguely recall FAA rules stating that all cargo must be securely fastened to prevent detachment?
  2. As a retired ejection seat engineer, I’m impressed by the work described in this video. Lots of good engineering experience for you, young man.
Leave a Reply to EntropyWarriorCancel reply
