If you’ve ever watched one of those high production value YouTube videos and wondered how they’re able to get those smooth shots where the camera seems to be spinning around an object, you were probably looking at the product of an motorized camera motion system. There’s no question these rigs can produce visually striking shots, but their high cost usually keeps them out of the hands of us lowly hackers.
Unless of course you do like [Andy], and build your own. The latest version of this impressive rig features the ability to continuously rotate thanks to commercial 12-wire slip rings, with optical endstops so the machine can still be homed at the beginning of a move. An onboard Raspberry Pi and Arduino Uno are responsible for controlling the stepper motors, the configuration of which ends up being reminiscent of a standard 3D printer.
The software [Andy] has come up with lets him synchronize the camera rig with a small rotating platform he built, which allows for even more complex shots as demonstrated in the video below. It also supports a very slick MQTT-enabled remote controller that he built as a previous project, which makes taking direct control over the camera and monitoring its status much easier.
Want to add a little polish to your own project videos? [Andy] has released all of the files and information you’d need to build your own version of his motion control rig, though we wouldn’t blame you for feeling a bit intimidated by this one. It might not be the most elaborate camera motion control system we’ve seen, but it’s certainly up there. If you just want an overhead video and don’t need those fancy tracking shots, perhaps a modified VESA arm would fit the bill.
Hey Tom,
thank you so much for the article!
This made my entire week!
Super cool of you to keep it open and give us your files and stuff.
I’ve used so much open source stuff for this and other projects, it wouldn’t feel right to keep it closed.
Don’t see a link to any files in the project?
There is a link to my repo on my project page and in the video description.
https://gitlab.com/pan-tilt-slider/PanTiltSlide-nodeJS
cheers cant see for looking
That is a beautiful build!
Thank you very much :)
Beautiful work. Sounds like the maker learned a lot along the way!
Thank you! He sure did :)
