One of the unexpected side effects of our this pandemic is a sudden growth in the global population of captive colonies of Lactobacillus bacteria and yeast. Also known as sourdough starters, they are usually found in jars with curious names written on top, living off a mixture of flour and water. They require close monitoring to keep them healthy and to determine when they are ready for baking. [Noah Feehan] has been working to instrument and automate the process for the past two years, and has created a high-tech jar to keep an eye on his sourdough starter.
For a sourdough starter to stay active, it must be kept within a certain temperature range, and performance is measured by how much the level inside the jar rises. Existing open source and commercial projects monitor these two parameters and transmit data out, but [Noah] wanted to include a few more features. The height of a sourdough starter rises due to the production of CO2, so he added an SCD-30 sensor module, which includes a temperature and humidity sensor. For level monitoring, an VL6180 time-of-flight sensor is mounted over a hole on top of the jar. [Noah] wanted to be able to see recent CO2 production and height stats right on the jar, a ESP32 module with onboard E-ink display was used. To draw air over the CO2 sensor at a constant rate, a small extraction fan was also added. Power is provided by a small LiPo battery. For long term logging, the data is sent over MQTT to a server running Mycodo environmental regulation software.
There are still several software improvements [Noah] would like to make, including battery life, user interface and alerts, but everything is open-source and available on GitHub, so feel free to jump in and build your own.
I recently quite enjoyed: https://www.amazon.co.uk/gp/product/B08CJ86Y1W
Which has a sourdough starter as one of the characters.
(It’s aimed at YA but I didn’t realise that when it popped up in my recommendations. But, like a lot of YA stuff it’s perfectly reasonable fantasy, just with extra plot holes)
What a fascinating idea. it gets my brain juices churning.
