Cool Binary Clock Uses Old-School LEDs And A Fancy Graphic PCB
Ah, the 5mm LED. Once a popular choice, they’ve been supplanted in modernity by smaller SMD components and/or more capable RGB parts in recent years. However, they’re still able to do the job and are a great way to give your project that proper homebrew look. [Ian Dunn] chose those very parts to produce his 4017 Decade Binary Clock.
The clock uses only digital logic ICs to tell the time – there are no microcontrollers here! After four or five iterations over almost a whole year, [Ian] was finally able to coax the circuit into reliable operation. As you’d expect, it relies on a 32.768 kHz crystal to provide a stable clock. Fed into a 4060 binary ripple counter, that clock is divided down 14 times to deliver a 2Hz square wave. This then goes through a 4027 flip flop to get the desired 1Hz signal. From there, a bunch of extra logic handles counting the seconds, minutes, and hours, and resetting the counters as appropriate.
The PCB that houses the project is printed on directly by a flatbed inkjet printer, which [Ian] purchased when inspired by our previous article on how to get your PCBs made at the mall. He didn’t actually use it to make the PCB in this case, but the flatbed printer does a great job of putting graphics on the board.
The result is quite an attractive look that might surprise a few electronics enthusiasts who haven’t seen a graphic printed board before. It’s a technique we think could be used to great effect on conference badges, too. If you’ve experimented with similar techniques, be sure to drop us a line!
21 thoughts on “Cool Binary Clock Uses Old-School LEDs And A Fancy Graphic PCB
  1. How is it a binary clock? To me, it appears that it has 10’s and 1’s places for the hours minutes and seconds that, and in this picture, reads exactly as printed: 6:36 and 57 seconds. Wouldn’t a binary clock actually display its time, in binary?
    1. It’s a decimal clock, not binary. Also what’s “old-school” about these LEDs? That they aren’t surface mount?
        1. I remember LEDs like that. The only reason you know they are on is they aren’t quite as bright when yiu remove the power.
          I can’t even remember where I got those floor sweepings, at a hamfest, but maybe elsewhere too. Imperfect cases, what seemed to be the wrong die in the package (so green die in a red colired package), and very weak output.
        2. You guys are correct, nothing old school about 5mm LED’s, it’s old school because it uses 4000 series digital logic from start to finish. There’s no micro controller or Raspberry Pi involved. I’m cooking up a clock that does use a true binary coded decimal output. Believe me, this format is a lot easier to read!
        3. The really old LEDs where red only, though you could alternatively drive a red LED in orange or yellow time limited modes for 3 and 2 ns respectively. LED color was often hard to identify after using these modes.
  2. Where’s the binary part of this “binary clock”? This is just a decimal clock using the PCB as the label for each digit.
    Neat PCB, but definitely not a binary clock, and not even BCD at that.
  3. I would not use these resistor networks, just connect all anodes together and use one resistor, as only one LED will be showing at one time.
    It’s a nice build!
  4. It’s a nice clock, but hackaday should know better than to repeat the designer’s mistake in calling it a “binary clock”. That has had a pretty well-established meaning for at least three decades. ThinkGeek has sold them, and see the January, 1991 issue of Popular Electronics for a kit (which I bought and built and still have running, btw :) ). https://worldradiohistory.com/Popular-Electronics-Guide.htm
Leave a Reply to alfcoderCancel reply
