GBA Remote Play Upgrade Lets You Play PlayStation On The Bus
The Nintendo Game Boy Advance was basically the handheld gaming situation of its era, by virtue of the fact that it had no serious competitors in the market. The system was largely known for 2D games due to hardware limitations.
However, [Rodrigo Alfonso] has recently upgraded his GBA Remote Play system that lets him play PlayStation games and others on his classic Game Boy Advance. We first featured this project back in July, which uses a Raspberry Pi 3 to emulate games and pipe video data to the handheld for display, receiving button presses in return.
Since then, [Rodrigo] has given the project some upgrades, in the form of a 3D-printed case that mounts a battery-powered Pi directly to the back of the console for portable play. Additionally, overclocking the GBA allows for faster transfer rates over the handheld’s Link Port, which means more pixels of video data can be clocked in. This allows for more playable frame rates when running at 240×160, the maximum resolution of the GBA screen.
The result is a Game Boy Advance which you can use to play Crash Bandicoot on the bus just to confuse the normies. Of course, one could simply build a Raspberry Pi handheld from scratch to play emulated games. However, this route takes advantage of the GBA form factor and is pretty amusing to boot. Video after the break.
4 thoughts on “GBA Remote Play Upgrade Lets You Play PlayStation On The Bus
  1. Since this is based on a Pi 3, I wonder how well a Pi Zero 2 would work instead. I’m kinda tempted to take a crack at this myself.
  2. Given the bitrate is just under 5Mbps, could an ESP32 be used to stream video from a PC? Hide a small gaming PC in a backpack and you can make the appearance of playing Crysis on a GBA.
Leave a Reply to SunooCancel reply
