Make Your Own Tabletop Game Organizers With Online Tool
There is a vibrant cottage industry built around selling accessories to improve the storage and organization of tabletop games, but the more DIY-minded will definitely appreciate [Steve Genoud]’s deckinabox tool, which can create either 3D-printable designs, or ones more suited to folded paper or cardstock. Making your own organizer can be as satisfying as it is economical, and [Steve]’s tool aims to make customization simple and easy.
The tool can also generate models for folded paper or cardstock.
The interface for customizing the 3D-printable token tray, for example, begins with a simple filleted receptacle which one can split into additional regions by adding horizontal or vertical separators. The default is to split a given region down the middle, but every dimension can of course be specified.  Things like filleting of edges (for easier token scooping) and other details are all handled automatically. A handy 3D view gives a live render of the design after every change.
[Steve] has a blog post that goes into some added detail about how the tool was made, and it makes heavy use of replicad, [Steve]’s own library for generating browser-based 3D models in code. Intrigued by the idea of generating 3D models programmatically, and want to use it to make your own models? Don’t forget to also check out OpenSCAD; chances are it’s both easier to use and more capable than one might think.
3 thoughts on “Make Your Own Tabletop Game Organizers With Online Tool
  1. This is great, and I could see it as a “first step” to something much better.
    I’d love to see a setting for variable material thickness, so that you could use this for things like foamcore or laser cut wood designs.
    A nice repository for shared designs wouldn’t hurt either.
    1. I found that all designs have a “Advanced” mode with some of them offering settings for core and wrapper material thickness. Would be nice to have that consistently on all designs.
Leave a Reply to TehDanCancel reply
