VFD Character Display Turned Into Audio VU Meter
Humans love visualising music, whether it’s in the form of an inscrutable equation drawing squiggles in Winamp, or a simple VU meter pulsing with the beat. This build from [mircemk] is of the latter variety, repurposing a VFD display to do the job.
The project is built around a VFM202MDA vacuum fluorescent display, which provides that lovely green-blue glow we all know and love, driven by a PT6314 driver chip. This has the benefit that it can be readily driven by a microcontroller in much the same way as the familiar HD44780 character LCD driver chip. With some minor tweaks, the character set can be modified to allow the display to become a surprisingly-responsive VU meter.
An Arduino Nano runs the show, with an envelope follower circuit feeding a signal for the left and right channels into the analog inputs of the microcontroller. The Arduino then measures the voltage on those inputs and feeds the necessary commands to the PT6314 driver to update the display.
The resulting VU meter has 38 bars per channel, and is highly responsive. The fast flickering of the meter bars in response to the music make it compelling to watch, and the era-appropriate enclosure the project is built in adds plenty to the aesthetic.
We’ve seen other VU meter builds before too, like this one that uses a little physics knowledge to create a more realistic analog-like needle meter. Video after the break.
8 thoughts on “VFD Character Display Turned Into Audio VU Meter
  1. Agree that VFD’s have a warm and responsive look to them. For some more idea’s… A device that was a most effective great looking VFD was the Logitech (SlimDevices) Squeezebox. It has at least a couple VU modes in it, including a mimic of a mechanical VU needle. See https://www.youtube.com/watch?v=ZHNOAELkYvE at 6:25 for the spectrum VU view and about 6:45 for the VU meter view.
  2. Due to using a diode to rectify the signal, this is going to be more of an “audio level meter” than an actual VU meter. The LM3916 datasheet has examples of op-amp half- and full-wave precision rectifiers.
  3. i wonder if a similar effect could be acieved using a flat oled, a grating and some proper plexiglass to mimic the look.
  4. I Did this a few year ago, next time I plan to do a spektrum analyzer since i have almost 75 of them in my stock :)
