Remote Screen Viewer Is Text-Only
Have you been slowly falling down a rabbit hole of Stallman-like paranoia of computers ever since installing Ubuntu for the first time in 2007? Do you now abhor anything with a GUI, including browsers? Do you check your mail with the command line even though you’re behind seven proxies? But, do you still want to play Minecraft? If so, this command-line-only screen viewer might just be the tool to use a GUI without technically using one.
This remote screen viewer is built in Python by [louis-e] and, once installed, allows the client to view the screen of the server even if the client is a text-only console. [louis-e] demonstrates this from within a Windows command prompt. The script polls the server screen and then displays it in the console using the various colors and textures available. As a result, the resolution and refresh rate are both quite low, but it is still functional enough to play Minecraft and do other GUI-based tasks as long as there’s no fine text to read anywhere.
The video below only shows a demonstration of the remote screen viewer, and we can imagine plenty of uses beyond this proof-of concept game demonstration. Installing a desktop environment and window manager is not something strictly necessary for all computers, so this is a functional workaround if you don’t want to waste time and resources installing either of those components. If you’re looking for remote desktop software for a more specific machine, though, take a look at this software which enables remote desktop on antique Macs.
5 thoughts on “Remote Screen Viewer Is Text-Only
  1. It feels as though this would be what Minecraft would look like, if I’d forgotten to bring my glasses.
    Awesome work, overlaying text as text would be a nice addition. I wonder how easily this could be translated to work for screenshots from any source, potentially opening the door to making pretty much anything available to the command line.
  2. Did you know that VLC does this by default? The default playback backend is colored text. I used to have a webcam on a laptop that I’d view over ssh.
  3. Interestingly there exists various terminals with support for graphics… Perhaps that’s a future expansion?
