Making The One Ring By Electroplating Gold On A 3D Print
Electroplating is a great way to add strength or shine to a 3D print. However, we don’t see too many people trying it with gold. [HEN3DRIK] isn’t afraid to experiment, though, and pulled off some amazing, high-quality jewelry-grade plating!
The design for the project was the so-called Ring of Power from Lord of the Rings. The print was created on a resin printer at a high quality level, washed thoroughly to remove any remaining resin, and then cured. The print was then post-processed with sandpaper to make it as smooth as possible. Conductive paint was then applied, ready to take on the plating layers. [HEN3DRIK] first started by plating copper to build up a tough base layer, then nickel to prevent mixing between the copper and gold. The gold is then finally plated on top. Plating the copper is done with the ring constantly rotating to get as even a coat as possible. In contrast, the gold plating is done with a brush to avoid wasting the highly-expensive plating solution.
The final result is a gleaming gold ring that probably feels strangely light in the hand. The technique is time consuming, thanks to the need to plate multiple layers, but the results are to die for. We’ve seen [HEN3DRIK]’s fine work before, too. Video after the break.
11 thoughts on “Making The One Ring By Electroplating Gold On A 3D Print
  1. But does it make you invisible? And do you have to go to Mount Doom in Mordor to destroy it?
    In any case, I’ll make an order. I need:
    Three rings for the Elven kings under the sky
    Seven for the Dwarf Lords in their halls of stone
    Nine for mortal Men doomed to die
    And for me, One ring to rule them all; one ring to find them; one ring to bring them all and in the darkness bind them, in the land of Mordor where all the Shadows lie. (But in a cross-genre joke, the Vorlons also lie)
Leave a Reply to pelrunCancel reply
