Put A Constellation In Your Dining Room
A black chandelier that looks somewhat like a fern frond. It has four lights arranged roughly in a circle around the curly end and two clustered near the tail. It is mounted on a dark wood panel ceiling.
We love lamps here at Hackaday, especially if they imitate natural light sources. [Scott McIndoe] used his love of lamps to fashion a chandelier replicating his favorite constellation, the Southern Cross.
Starting with the Southern Cross’s four major stars and the pointers of Alpha and Beta Centauri, [McIndoe] sketched out a breaking wave form between the six stars to form the spine of this light source. By using smart bulbs for each of the six star positions, he was able to set a scene that replicates the color and relative brightness of each star for that extra astronomical touch.
The top and bottom of the chandelier is laser cut from 3 mm plywood and fitted together using glue and finger joints while the sides are a wood veneer. The entire piece was sanded and coated with a bit of filler before painting. Mounting is accomplished using three eye hooks mounted on the top side of the chandelier.
If you want more celestial lamps, check out [McIndoe]’s previously-featured analemma chandelier or this lithophane moon lamp.
3 thoughts on “Put A Constellation In Your Dining Room
  1. “I drew a breaking wave form through all six stars. It had the happy result of generating a stylized koru” well done for spotting the reference, but also “haha NO”.
