Congratulations Low-Power Winners
Congratulations to the winners of the 2023 Hackaday.io Low Power Contest! We challenged you to show us how much you could do with how little, and you did not disappoint. Our judges have put their heads together, and thanks to Digi-Key, our contest sponsor, the top three entries will be taking home a $150 gift certificate for yet more hacking supplies.
We saw a great diversity of ideas here, all on the low-power theme. So without further ado…
The Prize Winners
[Christoph]’s Ultra Low Power RF-Sensor arose out of necessity. Having just repaired a shower drain, he couldn’t be sure that it wouldn’t start leaking again at some point in the future, but couldn’t go ripping up the floor under the shower tray every week to check. He needed a remote moisture sensor that would do the job for a long time with no intervention.
This superb solution combines an Atmel ATmega328P, an HDC1080 humidity sensor, a 433 MHz radio transmitter, and an RTC to keep power consumption super-low when everything else is shut down. Idling at 600 nA total most of the time, taking a reading every 15 minutes, this device should last for 12 years, and it’s been installed and running for five so far, so we’d say that it’s already proven itself very worthy of taking home the prize here.
[BleakyTex]’s Compact, low-power Geiger counter is absolutely the lowest power Geiger counter we’ve ever seen and maybe also the cutest. With the ambitious goal of running up to two years on two tiny LR44 batteries and a proven runtime of about six months by now, this is the radiation detector you can take with you every day, should you need to. The key is a custom HV section that’s designed for efficiency and the screen – even today, it’s still hard to beat the low power consumption of the humble LCD screen. All this, and it still makes those satisfying clicks when it’s enabled. [BleakyTex] says he might make a kit from this, and we absolutely hope he does!
[mircemk]’s Microwatt Pulse Motor took one of our suggestions in the announcement of the contest and ran with it. This eight-pole handmade electric motor doesn’t actually do anything other than spin, but it does that when hooked up to a literal potato. Pulling around 40 mA at 600 mV, it can easily run on solar power with enough power left over to charge up a battery for when the sun doesn’t shine. All of this is made with extremely simple circuitry and parts scavenged from old relays with a sewing needle held up by a magnet for the bearing. This is pure ingenuity and a sweet low-power demo.
Honorable Mentions
We had five honorable mention categories and more than enough awesome projects to go around, but we picked some anyway.
  • Sensible Sensors: We loved [Discreet Mayor]’s remote MQTT Long-Range Thermocouple Temp Sensor used for logging barbecue temperatures. That it could last for up to a year on a battery charge is impressive, but who’s grilling 365 days a year?
  • Artful Art: We had two nearly identical satellite circuit sculpture builds, and we just couldn’t choose. [Jordan Blanchard]’s MicroSat Circuit Sculpture takes pictures and sends them by FTP. It not only looks pretty but it is used to check the overhead conditions in his observatory. [Andrea Console]’s A little CSK satellite for a bright workstation is a beautiful and well-thought-out blinker. Both of them are solar and look sweet!
  • Battery Buster: Which project could go longest on a battery? It’s hard to tell, but [Josh EJ]’s Calendar Clock 50 Years Battery Life 1 AA Alkaline certainly has the most ambitious title. We kid. By slowing down the ticks of a clock mechanism, which are already obscenely power-saving, [Josh] estimates 6.2 uA of average current draw. Multiplying that out gets you 55 years on a battery, but at that point, you know the battery will die first. And the thing actually physically moves to boot!
  • Perpetual Motion: Since we already gave a prize to the pulse motor, a worthy shoutout goes to [JP Gleyzes] and the Kokot: a low-energy chicken coop door. This is a solar project that does one job: opening and closing a chicken coop door by day and night. We simply loved the practicality of the project, and since it’s solar, it’s one less thing he has to think about.
  • How Low? A number of projects did a great job documenting their low power use, but [Capt. Flatus O’Flaherty] (his real name, we presume) not only designed a power-off circuit but tested it well in the LoRa Dark Star project. If you’ve got a project that only needs to run intermittently and you want to reduce your overall power budget, definitely check out this work.
Thanks again to everyone who entered! The Low Power Challenge was a tremendous success. If you haven’t checked out all the entries, go do so and mention your own favorites down in the comments. We’d love to hear what struck your fancy.
And thanks again to Digi-Key for sponsoring!
13 thoughts on “Congratulations Low-Power Winners
      1. I’ve got a government issued certificate stating that human flesh is an essential part of my diet. Cannibalism is perfectly legal in my country.
        1. In my sci-fi world, some cannibal paparazzis dig in the trash of some social networks stars. They pick hair and other body sheds to convert to stem cells and grow in-vitro meat which is then sold to fans for consuming. Juicy.
          What about your world ?
  1. These are all great!
    I’d totally buy a kit for the lower-power geiger counter. I hope you make it happen BleakyTex!
  2. I think the LoRa Dark Star was the best entry (better than the three winners). Not only was it very low power it showed a lot of useful techniques that can be incorporated in lots of projects…
  3. Thanks for the mention, and congrats to the winners. It’s not 1 year, but 7 on a CR2032, but who’s counting? :-)
Leave a Reply to Reluctant CannibalCancel reply
