A 6502 Overlay Debugger
Retired hardware engineer [Plasmode] recently took on the challenge of building a debugger for the 6502 designed to sit atop the microprocessor while seated in a solder less breadboard. The result is the Diagnostic Overlay for W65C02 Breadboard, consisting of 128 kB SRAM and a 1250-gate CPLD. Except being 0.8 in wide, the overlay debugger is otherwise the same size as the 6502’s 40-pin DIP package, so it doesn’t overhang other portions of your circuit.
Being an initial concept prototype, [Plasmode] mounted the chips dead-bug style on perf board — a process he himself found tiring. If he builds additional debuggers, presumably he will consider making a PCB.
The prototype was constructed using point-to-point soldering with 30-ga wire wrap wire.  It was all done under the inspection microscope.  There are not many connections, but they are rather tedious so I can only do a dozen or so wires per session.  It took me 2 days and several hours total to finish the prototype board.
This design is based on the CRC65 Frugal 6502 Single Board Computer, of course omitting the 6502 itself. Instead of a physical ROM memory chip, he implemented a 64-byte boot loader inside the CPLD and a serial port. This lets him to bootstrap the system over the serial port. He plans on expanding this to include other DIP-packaged retro microprocessors in the future. Check out his Hackaday.io project page ( above ). If you want to dig deeper, he posted the schematics here.
6 thoughts on “A 6502 Overlay Debugger
  1. I’m a bit surprised this took over 2 days to solder. Sure, it’s quite finicky but it does not have that many wires. I’ve done some more complex projects myself in a similar way. The pitch was bigger (standard 2.54mm THT) but I also did not have a microscope back then. But in these modern times and with the quality of very capable PCB design programs and cheap PCB manufacturing, it makes more sense to design a “real” pcb for a project like this, even if it is a one off. If you have the ability to do isolation routing, then the whole project can also easily be done in less then a day.
  2. Where do you get the 5V tolerant EPLD ? I did not seem available on regular sources.
    Alternatively, is there any dev/breakout board for it ?
Leave a Reply to SpectrumCancel reply
