Drone Motion Capture, The Open Source Way
If you want to do some really advanced flying with drones, you typically need to be able to track them in space. [Joshua Bird] has whipped up a drone tracking system that can do the job for as little as $20 with millimeter-scale precision.
The system uses four PS3 Eye cameras which can be had second-hand at a cost of just $5 each. They’re modified by removing their IR cut filter, and putting in an IR-passing filter in the form of a cut-up slice of floppy disk. The system tracks the drones via their infrared indicators and the known locations of the four cameras themselves, which the system is capable of mapping out automatically. By using four cameras, the system is robust in the event the view of a camera is occluded. The system can track multiple drones at the same time, with [Joshua] demonstrating it working with two drones each carrying three infrared markers. He has the system set up to send positional updates to ESP32 microcontrollers on the drones themselves, which command the drones to hold them in set positions.
Code is available on GitHub for the curious. We’ve seen other similar work before, too.
4 thoughts on “Drone Motion Capture, The Open Source Way
    1. From that URL:
      WiFi positioning accuracy < 10 m, latenc 3 to 5 seconds to get a fix, the highest cost of the (radio based) systems they compare it to (which can be reduced if you already have a lot of APs, WiFi enabled sensors etc in place already).
      Not really a workable solution for positioning drones, let alone compared to 5 mm accuracy for $20!
Leave a Reply to OstracusCancel reply
