[Mellow Labs] wanted a smart washer and built a simple controller. However, he found out after a few weeks it wasn’t working how he wanted. The detergent quit flowing, and he washed clothes with no soap for a week! So, a redesign was in order. You can follow the process and the result in the video below.
A bit of 3D printing, a larger pump, and proper voltage made a big difference. We didn’t see the print files, but unless you have the exact same setup, you’d probably have to customize it anyway. There is a real-time hand-drawn schematic, and the software is probably not hard to pull off the video screen (it is only 18 lines).
