Non-Split-Flap Clock Does It With Fewer Flaps
A 3D-printed clock that uses flaps for the digits that get rotated.
As cool as split-flap clocks and displays are, they do have a few disadvantages. The mechanism sticks out on the side, and the whole thing relies on gravity. Some people don’t care for the visual split in the middle of each digit that comes as a result. And their cousins, the Numechron clocks? Those wheels, especially the hours wheel, are really big compared to the size of what they display, so the clock housings are huge by comparison.
[shiura] decided to re-invent the digital display and came up with this extremely cool spinning flap mechanism that uses a lip to flip each flap after it is shown. Thanks to this design, only half the number of flaps are needed. Not only is the face of the clock able to be much larger compared to the overall size of the thing, the whole unit is quite shallow. Plus, [shiura] tilted the display 15° for better visibility.
If you want to build one of these for yourself, [shiura] has all the STLs available and some pretty great instructions. Besides the printed parts, you don’t need much more than the microcontroller of your choice and a stepper motor. Check out the demo/build video after the break, and stick around for the assembly video.
Don’t mind the visual split in the numbers? Check out this split-flap clock that uses a bunch of magnets.
17 thoughts on “Non-Split-Flap Clock Does It With Fewer Flaps
  1. GE clocks from the early 70s used this exact design, with the dual sided flaps on a carousel that flipped over once per rotation. They even made some where they printed faux orange 7-segment numbers on the flaps to pretend to be a glowing digital display.
    1. Thank you for your comment. I think the design is almost identical except the motor position. Also National (domestic bland name of Panasonic in 1980s) sold similar clock named TE-818 and TE-814. That is also informed after the release of my clock through X (twitter) reply.
  2. Oh my god this is amazing… Could you make one that also does the day of the week? Even if it was just the first three letters that would be fantastic 🥰
Leave a Reply to MikeCancel reply
