We think it’s OK to admit that when someone puts a binary display on a project, it’s just a thinly veiled excuse to get more blinkenlights into the world. That and it’s a way to flex a little on the normies; you’ve gone pretty far down the tech rabbit hole to quickly decipher something like this binary-display thermometer, after all.
Don’t get us wrong, we think those are both perfectly valid reasons for going binary. And all things considered, a binary display for a thermometer like [Clovis Fritzen]’s is much simpler to decode than, say, a clock. Plus, it seems a bit that this build was undertaken at least partially as an exercise in Charlieplexing, which [Clovis] uses to drive the six-bit LED display using only three lines of GPIO from the Digispark ATtiny85 board running the show.
The temperature sensor is a DHT11, whose output is read by the microcontroller before being converted to binary and sent to the six-bit display. The 64-degree range is perfect for displaying the full range of temperatures most of us would consider normal, although we’d find 63°C a touch torrid so maybe there’s a little too much resolution on the upper end of the scale. Then again, switching to Fahrenheit would shift it toward the hypothermia end of the scale, which isn’t helpful. And you can just forget about Kelvin.
Nice job [Clovis]!
With red LEDs it would fit next to my Anelace binary clock.
Its a lot easier to get this from binary to celcius than C to F! Especially the shown temp because 1010b -> A hex -> 10 dec is one you can just glom instantly because of looking at test patterns.
Here in Scotland 31C is about as high a temperature as you would get outside a sauna, so we only need five bits. However, we get NEGATIVE temperatures. The easy way to signify these would be to use one LED as a sign bit; the PROPER way would be to write the two’s complement of the 5-bit temperature. Respect to anyone who can work that out in their head!
For me, it’s Kelvins in BCD or nothing. Moar lights!
I don’t like the word “normies” because it implies I’m an “abnormie”.
I think it’s funny how western hikikomori terminology and cultural artifacts have filtered into mainstream culture with a lag-time of about eight years and people aren’t usually aware of it. I wonder what current alt-chan speak is going to be in print publications circa 2030.
Don’t worry, everyone here is definitely 100% normie despite claims to the contrary
Thanks for the feature, did my best to bring some content about charlieplexing
that’s awesome! compared to yours mine is simple haha https://www.slyautomation.com/blog/dht11-with-arduino/ , it just printing the output but i think i’ll add this visual to mine and maybe upgrade the sensor to a BME280!
