For months before liftoff, the popular press had been hyping up the fact that the Polaris Dawn mission would include the first-ever private spacewalk. Not only would this be the first time anyone who wasn’t a professional astronaut would be opening the hatch of their spacecraft and venturing outside, but it would also be the first real-world test of SpaceX’s own extravehicular activity (EVA) suits. Whether you considered it a billionaire’s publicity stunt or an important step forward for commercial spaceflight, one thing was undeniable: when that hatch opened, it was going to be a moment for the history books.
But if you happened to have been watching the live stream of the big event earlier this month, you’d be forgiven for finding the whole thing a bit…abrupt. After years of training and hundreds of millions of dollars spent, crew members Jared Isaacman and Sarah Gillis both spent less than eight minutes outside of the Dragon capsule. Even then, you could argue that calling it a spacewalk would be a bit of a stretch.
Neither crew member ever fully exited the spacecraft, they simply stuck their upper bodies out into space while keeping their legs within the hatch at all times. When it was all said and done, the Dragon’s hatch was locked up tight less than half an hour after it was opened.
Likely, many armchair astronauts watching at home found the whole thing rather anticlimactic. But those who know a bit about the history of human spaceflight probably found themselves unable to move off of the edge of their seat until that hatch locked into place and all crew members were back in their seats.
Flying into space is already one of the most mindbogglingly dangerous activities a human could engage in, but opening the hatch and floating out into the infinite black once you’re out there is even riskier still. Thankfully the Polaris Dawn EVA appeared to go off without a hitch, but not everyone has been so lucky on their first trip outside the capsule.
A High Pressure Situation
The first-ever EVA took place during the Voskhod 2 mission in March of 1965. Through the use of an ingenious inflatable airlock module, cosmonaut Alexei Leonov was able to exit the Voskhod 3KD spacecraft and float freely in space at the end of a 5.35 m (17.6 ft) tether. He attached a camera to the outside of the airlock, providing a visual record of yet another space “first” achieved by the Soviet Union.
This very first EVA had two mission objectives, one of which Leonov had accomplished when he successfully rigged the external camera. The last thing he had to do was turn around and take pictures of the Voskhod spacecraft flying over the Earth — a powerful propaganda image that the USSR was eager to get their hands on. But when he tried to activate his suit’s camera using the trigger mounted to his thigh, he found he couldn’t reach it. It was then that he realized the suit had begun to balloon around him, and that moving his arms and legs was taking greater and greater effort due to the suit’s material stiffening.
After about ten minutes in space Leonov attempted to re-enter the airlock, but to his horror found that the suit had expanded to the point that it would no longer fit into the opening. As he struggled to cram himself into the airlock, his body temperature started to climb. Soon he was sweating profusely, which pooled around his body within the confines of the suit.
Unable to cope with the higher than anticipated internal temperature, the suit’s primitive life support system started to fail, making matters even worse. The runaway conditions in the suit caused his helmet’s visor to fog up, which he had no way to clear as he was now deep into a failure mode that the Soviet engineers had simply not anticipated. Not that they hadn’t provided him with a solution of sorts. Decades later, Leonov would reveal that there was a suicide pill in the helmet that he could have opted to use if need be.
With his core temperature now elevated by several degrees, Leonov was on the verge of heat stroke. His last option was to open a vent in his suit, which would hopefully cause it to deflate enough for him to fit inside the airlock. He noted that the suit was currently at 0.4 atmosphere, and started reducing the pressure. The safety minimum was 0.27 atm, but even at that pressure, he couldn’t fit. It wasn’t until the pressure fell to 0.25 atm that he was able to flex the suit enough to get his body back into the airlock, and from there back into the confines of the spacecraft.
In total, Alexei Leonov spent 12 minutes and 9 seconds in space. But it must have felt like an eternity.
Gemini’s Tricky Hatch
In classic Soviet style, nobody would know about the trouble Leonov ran into during his spacewalk for years. So when American astronaut Ed White was preparing to step out of the Gemini 4 capsule three months later in June of 1965, he believed he really had his work cut out for him. Not only had the Soviets pulled off a perfect EVA, but as far as anyone knew, they had made it look easy.
So it’s not hard to imagine how White must have felt when he pulled the lever to open the hatch on the Gemini spacecraft, only to find it refused to budge. As it so happens, this wasn’t the first time the hatch failed to open. During vacuum chamber testing back on the ground, the hatch had refused to lock because a spring-loaded gear in the mechanism failed to engage properly. Luckily the second astronaut aboard the Gemini capsule, James McDivitt, was present when they had this issue on the ground and knew how the latch mechanism functioned.
McDivitt felt confident that he could get the gear to engage and allow White to open the hatch, but was concerned about getting it closed. Failing to open the hatch and calling off the EVA was one thing, but not being able to secure the hatch afterwards meant certain death for the two men. Knowing that Mission Control would almost certainly have told them to abort the EVA if they were informed about the hatch situation, the astronauts decided to go ahead with the attempt.
As he predicted, McDivitt was able to fiddle with the latching mechanism and got the hatch open for White. Although there were some communication issues during the spacewalk due to problems with the voice-operated microphones, the EVA went very well, with White demonstrating a hand-held maneuvering thruster that allowed him to fly around the spacecraft at the end of his tether.
White was having such a good time that he kept making excuses to extend the spacewalk. Finally, after approximately 23 minutes, he begrudgingly returned to the Gemini capsule — informing Mission Control that it was “the saddest moment of my life.”
The hatch had remained open during the EVA, but now that White was strapped back into the capsule, it was time to close it back up. Unfortunately, just as McDivitt feared, the latches wouldn’t engage. To make matters worse, it took White so long to get back into the spacecraft that they were now shadowed by the Earth and working in the dark. Reaching blindly inside the mechanism, White was once again able to coax it into engaging, and the hatch was securely closed.
But there was still a problem. The mission plan called for the astronauts to open the hatch so they could discard unnecessary equipment before attempting to reenter the Earth’s atmosphere. As neither man was willing to risk opening the hatch again, they instead elected to stow everything aboard the capsule for the remainder of the flight.
Overworked, and Underprepared
At this point the Soviet Union and the United States had successfully conducted EVAs, but both had come dangerously close to disaster. Unfortunately, between the secretive nature of the Soviets and the reluctance of the Gemini 4 crew to communicate their issues to Mission Control, NASA administration started to underestimate the difficulties involved.
NASA didn’t even schedule EVAs for the next three Gemini missions, and the ambitious spacewalk planned for Gemini 8 never happened due to the mission being cut short due to technical issues with the spacecraft. It wouldn’t be until Gemini 9A that another human stepped out of their spacecraft.
The plan was for astronaut Gene Cernan to spend an incredible two hours outside of the capsule, during which time he would make his way to the rear of the spacecraft where a prototype Astronaut Maneuvering Unit (AMU) was stored. Once there, Cernan was to disconnect himself from the Gemini tether and don the AMU, which was essentially a small self-contained spacecraft in its own right.
But as soon as he left the capsule, Cernan reported that his suit had started to swell and that movement was becoming difficult. To make matters worse, there were insufficient handholds installed on the outside of the Gemini spacecraft, making it difficult for him to navigate his away along its exterior. After eventually reaching the AMU and struggling desperately to put it on, Mission Control noted his heart rate had climbed to 180 beats per minute. The flight surgeon was worried he would pass out, so Mission Control asked him to take a break while they debated if he should continue with the AMU demonstration.
At this point Cernan noted that his helmet’s visor had begun to fog up, and just as Alexei Leonov had discovered during his own EVA, the suit had no system to clear it up. The only way he was able to see was by stretching forward and clearing off a small section of the glass by rubbing his nose against it. Realizing the futility of continuing, Commander Thomas Stafford decided not to wait on Mission Control and ordered Cernan to abort the EVA and get back into the spacecraft.
Cernan slowly made his way back to the Gemini’s hatch. The cooling system in his suit had by now been completely overwhelmed, which caused the visor to fog up completely. Effectively blind, Cernan finally arrived at the spacecraft’s hatch, but was too exhausted to continue. Stafford held onto Cernan’s legs while he rested and finally regained the strength to lower himself into the capsule and close the hatch.
When they returned to Earth the next day, a medical examination revealed Cernan had lost 13 pounds (5.8 kg) during his ordeal. The close-call during his spacewalk lead NASA to completely reassess their EVA training and procedures, and the decision was made to limit the workload on all future Gemini spacewalks, as the current air-cooled suit clearly wasn’t suitable for long duration use. It wasn’t until the Apollo program introduced a liquid-cooled suit that American astronauts would spend any significant time working outside of their spacecraft.
The Next Giant Leap
Thanks to the magic of live streaming video, we know that the Polaris Dawn crew was able to complete their brief EVA without incident: no shadowy government cover-ups, cowboy heroics, or near death experiences involved.
With the benefit of improved materials and technology, not to mention the knowledge gained over the hundreds of spacewalks that have been completed since the early days of the Space Race, the first private spacewalk looked almost mundane in comparison to what had come before it.
But there’s still much work to be done. SpaceX needs to perform further tests of their new EVA suit, and will likely want to demonstrate that crew members can actually get work done while outside of the Dragon. So it’s safe to assume that when the next Polaris Dawn mission flies, its crew will do a bit more than just stick their heads out the hatch.
Honestly, I was very disappointed due to the suit itself: it had neither thermal insulation nor water-based cooling, so the capsule had to be oriented to guarantee that it was in the shadow and avoid overheating. It lacked micrometeoroid protection, so the capsule’s cone was put in a way to protect it from impacts. It lacked closed-circuit breathing system, so it was constantly leaking air to space…
In my opinion, it is basically an IVA suit with some little add-ons (the sun filter in the helmet and the ball-bearings in the shoulders), not a true EVA suit.
It was basically a human-shaped bag.
It is almost certainly the most primitive thing a human has ever spacewalked in and the fact that this was allowed to proceed is horrifying.
The account here of the over-expansion of Leonov’s space suit and his inability to fit through the hatch to return to his capsule is the stuff from which nightmares are made.
I would honestly have loved a brief explanation on why the suits were doing that.
The void of space vs the air pressure inside of the suit. Imagine a helium filled balloon rising in the atmosphere, expands until it bursts since the air pressure exerted on it reduces with altitude. ✨🌎
You are just stating the obvious. The question is why didn’t the suit do this when tested on earth.
It’s pretty obvious that it was the result of insufficient testing in a rush to make an artificial deadline. But that was typical for the Soviet space program. Nedelin disaster is a good example of how things could go wrong.
And letting the air out of his suit, the thing keeping him alive. Brave guy.
He didn’t have many other options 🚀
It’s not as bad as it may sound. The human skin has a certain resistance (and a thin thermal layer).
Even in a vaccuum, it still keeps the blood from boiling. But things like hands may swell, which is counter productive.
The thermal layer thing can be seen “in action” when funny dudes play with liquid nitrogen.
ISTR Chris Hadfield telling a story about the visor anti-fogging stuff getting in his eyes and blinding him on a spacewalk and that alone was nightmare fuel, never mind the suit or hatch problems mentioned in this article.
Yes, in his memoirs. IIRC it was literal bleach.
Yeah… sounds like the kind of dreams I have when I’m really stressed.
I think Luca Parmitano’s experience of nearly drowning from a water leak in his suit during an EVA in 2013 is much more terrifying.
Didn’t the US and the USSR test the suits in a vacuum chamber before actual use?
I’m sure they did, but you don’t know what you don’t know, and during the early days of an exciting new project you’re always making do with less than you need.
These days the whole mission would be dry run on the ground, but even that might not find issues with the cooling systems, or the physical exertion required.
Or like the Americans with the sticky hatch, they knew on the ground but said, send it.
It’s pretty hard to simulate the effects of the sun on the spacesuits.
Nice work Tom. I did not know any of this stuff!
Nowadays, there are lots of videos that combine multiple sources of the original space film footage. (Naturally there’s more footage available of American sources than Soviet ones.) Of the Gemini spacewalk, I like this one. Note that the 24fps frame rate is interpolated for the original 6fps, so it’s not “pure”. But you can tell their first-time awkwardness.
https://www.youtube.com/watch?v=yUXyJsbwFtw
Stockton Rush probably disagrees with that.
I doubt that, I haven’t heard anything from him in over a year…
“Flying into space is already one of the most mindbogglingly dangerous activities a human could engage in”
Exotic, expensive and, yes, dangerous. But in deaths per passenger mile it’s safer than automobile travel.
To be fair, If my car could go 17,500 miles per hour, I’d expect some deaths to occur.
Pretty big gap in your little history there, what about a discussion of the MMU “backpack” style thruster unit which was used with some of the shuttle missions. We didn’t just go straight from Gemini to Polaris.
Interesting that both the Soviets and Americans had trouble with overinflated suits though, did neither of them perform enough vacuum tests beforehand?
I think the thruster method is irrelevant to the question whether the suit is capable of enduring outer space. Okay, it’ll make the astronaut a little more bulky, but isn’t it mostly a different form factor of the handheld thruster? It was mostly about pressure and heat management.
Let’s don’t despair. China has just shown new spacesuits, too.
Maybe their concepts can be learned from?
https://spacenews.com/china-unveils-lunar-spacesuit-for-crewed-moon-mission/
Micrometeoroid caused Lobotomy :D
Whoopee! A billionaire funds some joy rides for civilians and they do something done back in the 1960s. Human spaceflight is incredibly wasteful of limited space science funds with a huge cost versus science return ratio. It is SO 1960s. Book: The End of Astronauts: Why Robots are the Future of Exploration (2022)
To be fair, those astronauts here are no laymen by any means.
They did work for years in the space industry and even alongside regular astronauts.
So it’s not quite fair to call them “hobby astronauts” or something like that, as the international press does.
These astronauts here did go through similar if not same procedures like traditional NASA/ESA astronauts do.
It’s just that they fly for a private organization. It doesn’t automatically mean they’re lesser competent whatsoever.
By that logic, human existance itself is pointless. Too wasteful. So let’s just put an end to it, too?
It would safe money, after all. We’d nolonger need to spend money on living costs.
Seriously, though. What is the purpose of space exploration, if not curiosity? Or should I say “the driving force”?
Humanity reaches for the stars since ancient times. For much longer than the USA and those know-it-all economists existed.
It’s not about gathering numbers, but about reaching new horizons. Sailing into the unknown.
Human beings want to be “be out there”.
Those who come up with economics have understood nothing.
Fascination is what’s it all about. That’s why scientists become scientist and why astronauts become astronauts.
Ok, except for USA maybe. NASA and company are into gold rush currently.
They want to capitalize, commercialize and exploit space.
Not all space agencies are like that, though. That alone is why the book is wrong. It should have “[..] in the USA” in the title, maybe.
Try looking at private space flight a diffferent way, it could be humanities best hope for jettisoning unwanted and unnecessary billionares while also providing a mechanism for re-distributing some of the wealth they’ve amassed.
The irony is that rich people such as celebrities seek for a purpose in life, while many of us just do mindless work, day for day.
Money has become more of an instrument to the rich and beautiful, not their purpose of living.
They rather wish for real friends and want to be truely loved, which remains a distant dream to them.
And that’s why they do really suffer sometimes or get depressions, loose connection to reality etc.
The money gets in the way.
Everyone around them nolonger sees the person, but a walking bag of money.
By contrast, not seldomly it’s the small people who’re after money all time and take friends and family for granted.
So which character type is more noble here?
The baby must leave the cradle.
How exactly was this “wasteful of space science funds’? It was privately funded. Whoopee, they already did it back in the ’60s? Ya, private citizens walking space for the first time ever is pretty big accomplishment…exponentially larger than anything you will accomplish in your life.
No “limited space science funds” were used for this mission. It was entirely paid for by private persons.
“It wasn’t until the Apollo program introduced a liquid-cooled suit ”
Wow. Gemini suits didn’t use liquid??? I can’t believe that functioned at all!
Suit should have some beef in case of a fix quick. Tech Ingredients showed how some peltiers work. Enough range? Mckibben net?
For the story of Alexis Leonov, I recommend watching the 2017 Russian film “The Spacewalker” – which is not exactly pro-Soviet propaganda.
I had read somewhere (can’t remember the reference) that Leonov suffered a heart attack during the physical ordeal of re-entry into the airlock and that he only survived thanks to cardiac massage provided by his crewmate. However, the two cosmonauts were not at the end of their troubles since their capsule, following various failures, landed several hundred kilometers from the planned point.
All these adventures of space pioneers make me think that these guys are not quite built like ordinary mortals – both physically and especially mentally. And very, very far from today’s billionaire neo-astronauts !
