Keebin’ With Kristina: The One With The Funny Keyboard
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
What’s the most important keyboard macro you know? Honestly, it’s probably Ctrl-S. But do you use that one often enough? Chances are, you do not. What you need is a giant, dedicated Save keyboard that looks like a floppy disk.
A physical Save button that looks like a floppy disk and sends Ctrl-S over USB-C.
Image by [Makestreme] via Hackaday.IO
[Makestreme] recently started creating YouTube videos, but wasn’t pressing Save often enough. Couple that with editing software that crashes, and the result is hours of lost work.
Just like you’d expect, pressing the floppy icon triggers Ctrl-S when connected over USB-C. Internally, it’s a Seeeduino Xiao, a push button, and some wires.
The floppy disk itself is made of foam board, and everything is encased in a picture frame. If you want to make one for yourself, [Makestreme] has some great instructions over on IO.
Folding Keyboard Working After Five Hours of Debugging
Wishing for something compact and foldable, [sushiiiiiiiiiiiiii] created this seemingly nameless wonder that sort of resembles a concertina. The initial idea was to have both halves separate and make the thumb cluster unfold, but the making the linkage work correctly turned out to be a nightmare.
A prototype of a keyboard with wonderful marshmallow-y keys on both the front and the back.
Image by [sushiiiiiiiiiiiiii] via reddit
Internally, this keyboard sports a pair of SuperMini nRF52840s plus a third one to make into a dongle. Those switches are Kailh Deep Sea Tactile Whales, which are silent, low-profile numbers.
They are topped with beautiful KLP Lamé keycaps I’d really like to touch that [sushiiiiiiiiiiiiii] had printed through JLC. It runs on six IKEA LADDA Ni-MH AAA cells [sushiiiiiiiiiiiiii] had laying around that the integrated Li-ion charger “shouldn’t explode” based on research.
Programming was a different kind of nightmare. [sushiiiiiiiiiiiiii] went through the ZMK setup, but the thing just would not show up on any Bluetooth device. After several hours of checking absolutely everything, [sushiiiiiiiiiiiiii] went back to the guide and discovered the programmer’s bane — an errant space after a comma that screwed everything up. The next version will have a reworked hinge and be less wobbly.
The Centerfold: A Little Comic Relief
A comic book-inspired keyboard on a wavy black and white desk mat.
Image by [xfactorxsuh] via reddit
Yes, this is an actual keyboard with actual keycaps. Although it would probably give most people a headache after a while, this setup is pretty darn cool. As you can see in the pictures, [xfactorxsuh] covered an existing keyboard of unknown-to-me make and model with masking tape and then went to town with a fine-tipped black marker. This was done to match the PBT comic book keycaps, which actually come that way from Ali.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: Defi-ing Typical Typewriter Prices
The Defi typewriter, which cost a mere $25 in the early 1900s.
Image via The Antikey Chop
First and foremost: although it looks nice, the reason why this Defi is screwed to a metal base is unknown. This typewriter came standard with a wood base and cost a mere $25 in the early 1900s, whereas most machines were more like $60-$100. A metal base would probably have made it cost more.
The Defi was built with a three-row, 84-character keyboard bearing two Shifts, presumably one for upper case, and the other for figures and symbols. From here, it looks as though every key has a second function, which gives it a really nice balance between usability and portability.
One of the most interesting bits to me is the semi-circular type element, which looks like one of those old rocking desk ink blotter things. Speaking of ink, the Defi used a ribbon spool. The whole thing was only a foot square and five inches tall, weighing about nine pounds total, presumably with the wood base.
ICYMI: the Lancaster ASCII keyboard Clacks Again
If you want a cool keyboard in 2024, you’re probably gonna have to build it yourself. And if you wanted a cool keyboard fifty years ago, you definitely had to build it yourself.
The Lancaster ASCII keyboard, recreated.
Image by [Artem Kalinchuk] via GitHub
But much like today, help was out there in the form of  magazines. One such publication, the February 1973 issue of Radio Electronics in fact, had [Don Lancaster]’s plans for an ASCII keyboard that went along with a “TV Typewriter”.
[Artem Kalinchuk] wanted to recreate this famous keyboard, and he did, twice. One PCB is true to the original key switches, and the other, more practical version is made for the MX footprint. Both are up on GitHub if you’re interested.
While the board itself is nice, you would also need the ASCII encoder board, which is fairly simple with a few ICs, diodes, and a couple of transistors. I really love the look of this keyboard, and although far more practical, it would be a shame to cover up all that beautiful wiring. Perhaps clear acrylic is in order?
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
19 thoughts on “Keebin’ With Kristina: The One With The Funny Keyboard
      1. The button that looks like a generic-character-rectangle with “23” in the top half and “FB” in the bottom half? That’s how my web browser renders it.
        A quick copy-and-paste to word processor gave the big reveal. Maybe the “23/FB rectangle” is my web browser’s version of a molly-guard.
        1. Molly-guard. I was trying to remember that the other day.
          In reference to the “WTF were they thinking” Apple II reset switch right next to the “Return” key.
          1. The molly-guard for that was to put an O-ring around the reset key stem. If you wanted to press it, you had to really mean it.
        2. When editing a table in MS Word, you select the whole table with Alt+Numpad 5.
          Once you move to a TKL or smaller layout, this needs to be a cutom macro anyway.
  1. I was looking at the image of the Defi and couldn’t identify the mentioned type element, and started to wonder if I was seeing an AI image. It turns out the shown typewriter is incomplete. A complete one with the type element can be viewed here: http://www.typewriterstory.com/defi-typewriter/
    I also couldn’t figure out the platen. Turns out it strikes the paper from behind to print the characters onto the paper.
    1. that looks an awful lot like the way my Varityper 1010 works. although that one is way bigger and heavier due to the whole proportional typing thing and justification system.
  2. The “unknown-to-me make and model” headache-inducing keyboard looks identical (less the visual enhancements) to my cheap-but-entirely-adequate off-brand mechanical from Amazon. Mine branded “REDRAGON K552”. Excellent, once I gave it a LEDectomy and a few dozen o-rings to quiet it down a bit and soften the bottom-out feel.
  3. [Kristina],
    I couldn’t help but wonder if you added an extra “i” every time you inserted [sushiiiiiiiii] into the text.
    B^)
