Casio Calculator Gets New Keyboard
What do you do with a circa 1985 Casio FX-451 calculator with a bad keyboard? Well, if you are [Poking Technology], you transplant the inside of the calculator to a new custom keyboard. There are two videos that cover the process in detail, which you can watch below.
The calculator has a unique design. It looks like a simple calculator in a wallet. But the wallet opens to reveal an extended keyboard with all the scientific features onboard. Unsurprisingly, the membrane keys didn’t survive over four decades. Disassembling the unit was a challenge. Soldering wires to the keyboard lines was further complicated by the fact that some of the lines are on the back of the PCB and pass through to the top under the main IC.
The new keyboard is quite a bit larger than the original, making this more of a desk calculator, but that also means you can use high-quality keys. We’d love to see a 3D printed case to wrap it all up, but the bare PCB look has its charms, too.
If you can’t understand how [Poking] can love a calculator so much, you probably never owned an HP-41C, either. Of course, our retro calculator dreams also include Star Trek.
6 thoughts on “Casio Calculator Gets New Keyboard
  1. I had this very calculator during the 1980s. The solar panels relieved me of the tyranny of battery changes (and made it thinner) and the fold-out design was very efficient and easy to use, as opposed to poring over minute keys with tiny labels. The only problem was that when it was stored in a pocket in its folded condition it became reluctant to unfold again.
  2. Still using my 1982 FX450, though the hinge point is a bit iffy the solar cell still makes enough juice to drive it and the fold out kb still works. at least enough for trig and hex calculations, though it will not lay flat on a desk.
  3. Hey, this project looks familiar! (It’s mine.)
    I agree with the solar panel comments. Cheap ones from Aliexpress are easy to source and would avoid having to think about batteries. The downside is that it would require me to wipe up the total-reset button again, and I don’t really like it much (it resets everything, including memory and modes).
    The main thing the project did is teach me a hell of a lot about how not to design PCBs.
  4. Back in the 70’s (after we’d eaten the last dinosaur) I took my calculator and spread the guts out on a literal breadboard. I found out how VFDs worked, and what keyboard matrices were. I found it had Pi and square root functions that weren’t on the original layout, and added contacts for them when I reassembled it.
  5. I still use my casio fx120 I purchased in 1979 it still works perfect casio made the best calculators it outlived 2 lcd calculatirs I still use my psion lz64 as well
Leave a Reply to StephenCancel reply
