Twisting Magnetism To Control Electron Flow
Microscopic view of chiral magnetic material
If you ever wished electrons would just behave, this one’s for you. A team from Tohoku, Osaka, and Manchester Universities has cracked open an interesting phenomenon in the chiral helimagnet α-EuP3: they’ve induced one-way electron flow without bringing diodes into play. Their findings are published in the Proceedings of the National Academy of Sciences.
The twist in this is quite literal. By coaxing europium atoms into a chiral magnetic spiral, the researchers found they could generate rectification: current that prefers one direction over another. Think of it as adding a one-way street in your circuit, but based on magnetic chirality rather than semiconductors. When the material flips to an achiral (ferromagnetic) state, the one-way effect vanishes. No asymmetry, no preferential flow. They’ve essentially toggled the electron highway signs with an external magnetic field. This elegant control over band asymmetry might lead to low-power, high-speed data storage based on magnetic chirality.
If you are curious how all this ties back to quantum theory, you can trace the roots of chiral electron flow back to the early days of quantum electrodynamics – when physicists first started untangling how particles and fields really interact.
There’s a whole world of weird physics waiting for us. In the field of chemistry, chirality has been covered by Hackaday, foreshadowing the lesser favorable ways of use. Read up on the article and share with us what you think.
11 thoughts on “Twisting Magnetism To Control Electron Flow
  1. Stuff like this does make me wonder if a small change or two in our history could have lead to the development electronics that are based on something other than semiconductors.
    1. The adoption of glass is a possible lynchpin in the history of electronics development. If we had stuck with ceramic, we may well not have started making electronic valves, etc.
      1. A substitute for metal would be nice too but at the end of the day it’s just a game of ookie-cookie.
  2. If anyone finds this sort of topic interesting ( making electrons do funky things), i urge you to take a look at devices that use Tunneling Magneto Resistance (TMR).
    So far i have seen “encoders,” memory, and current sensors all based on the effect and all commercially available for the home gamer.
    I remember just a few years ago my college physics professor explaining how the wage of “spintronics” was going to next big thing. Little did i know, i guess the time is already upon us!
  3. “They’ve essentially toggled the electron highway signs with an external magnetic field. This…” – so they created a reed relay?
    1. A relay toggles an electrical connection but does nothing about control direction of current. This chiral magnet controls current direction but does nothing to the electrical connection
  4. Isn’t this basically how RF circulators work? I’ve wondered for years whether a switchable circulator could be built using electromagnets instead of permanent magnets.
Leave a Reply to J D RocketfellerCancel reply
