Crossing Commodore Signal Cables On Purpose
On a Commodore 64, the computer is normally connected to a monitor with one composite video cable and to an audio device with a second, identical (although uniquely colored) cable. The signals passed through these cables are analog, each generated by a dedicated chip on the computer. Many C64 users may have accidentally swapped these cables when first setting up their machines, but [Matthias] wondered if this could be done purposefully — generating video with the audio hardware and vice versa.
Getting an audio signal from the video hardware on the Commodore is simple enough. The chips here operate at well over the needed frequency for even the best audio equipment, so it’s a relatively straightforward matter of generating an appropriate output wave. The audio hardware, on the other hand, is much less performative by comparison. The only component here capable of generating a fast enough signal to be understood by display hardware of the time is actually the volume register, although due to a filter on the chip the output is always going to be a bit blurred. But this setup is good enough to generate large text and some other features as well.
There are a few other constraints here as well, namely that loading the demos that [Matthias] has written takes so long that the audio can’t be paused while this happens and has to be bit-banged the entire time. It’s an in-depth project that shows mastery of the retro hardware, and for some other C64 demos take a look at this one which is written in just 256 bytes.
Thanks to [Jan] for the tip!
19 thoughts on “Crossing Commodore Signal Cables On Purpose
  1. “so long that the audio can’t be paused while this happens and has to be bit-banged the entire time.”
    Do you mean the audio that is video or the video that is audio?
  2. That’s awesome!! I have tried connecting the audio to the monitor and composite to the stereo myself on the Amiga, but never tried to actually make a useful signal out of it on either output…
  3. “Excuse me Egon, you said crossing the streams was bad. You are going to endanger us. You are going to endanger our client, a nice lady who paid us in advance before she became a dog”
  4. I can’t be the only one bothered by the low poly giant A/V cables 🤦🏼‍♂️. What’s terrible is many CAD programs smooth it on screen while the mesh is low poly. And it really doesn’t need to be.
    Cool hack, very nice.
Leave a Reply to AdamCancel reply
