Big Chemistry: Cement And Concrete
Not too long ago, I was searching for ideas for the next installment of the “Big Chemistry” series when I found an article that discussed the world’s most-produced chemicals. It was an interesting article, right up my alley, and helpfully contained a top-ten list that I could use as a crib sheet for future articles, at least for the ones I hadn’t covered already, like the Haber-Bosch process for ammonia.
Number one on the list surprised me, though: sulfuric acid. The article stated that it was far and away the most produced chemical in the world, with 36 million tons produced every year in the United States alone, out of something like 265 million tons a year globally. It’s used in a vast number of industrial processes, and pretty much everywhere you need something cleaned or dissolved or oxidized, you’ll find sulfuric acid.
Staggering numbers, to be sure, but is it really the most produced chemical on Earth? I’d argue not by a long shot, when there’s a chemical that we make 4.4 billion tons of every year: Portland cement. It might not seem like a chemical in the traditional sense of the word, but once you get a look at what it takes to make the stuff, how finely tuned it can be for specific uses, and how when mixed with sand, gravel, and water it becomes the stuff that holds our world together, you might agree that cement and concrete fit the bill of “Big Chemistry.”
Rock Glue
To kick things off, it might be helpful to define some basic terms. Despite the tendency to use them as synonyms among laypeople, “cement” and “concrete” are entirely different things. Concrete is the finished building material of which cement is only one part, albeit a critical part. Cement is, for lack of a better term, the glue that binds gravel and sand together into a coherent mass, allowing it to be used as a building material.
What did the Romans ever do for us? The concrete dome of the Pantheon is still standing after 2,000 years. Source: Image by Sean O’Neill from Flickr via Monolithic Dome Institute (CC BY-ND 2.0)
It’s not entirely clear who first discovered that calcium oxide, or lime, mixed with certain silicate materials would form a binder strong enough to stick rocks together, but it certainly goes back into antiquity. The Romans get an outsized but well-deserved portion of the credit thanks to their use of pozzolana, a silicate-rich volcanic ash, to make the concrete that held the aqueducts together and built such amazing structures as the dome of the Pantheon. But the use of cement in one form or another can be traced back at least to ancient Egypt, and probably beyond.
Although there are many kinds of cement, we’ll limit our discussion to Portland cement, mainly because it’s what is almost exclusively manufactured today. (The “Portland” name was a bit of branding by its inventor, Joseph Aspdin, who thought the cured product resembled the famous limestone from the Isle of Portland off the coast of Dorset in the English Channel.)
Portland cement manufacturing begins with harvesting its primary raw material, limestone. Limestone is a sedimentary rock rich in carbonates, especially calcium carbonate (CaCO3), which tends to be found in areas once covered by warm, shallow inland seas. Along with the fact that limestone forms between 20% and 25% of all sedimentary rocks on Earth, that makes limestone deposits pretty easy to find and exploit.
Cement production begins with quarrying and crushing vast amounts of limestone. Cement plants are usually built alongside the quarries that produce the limestone or even right within them, to reduce transportation costs. Crushed limestone can be moved around the plant on conveyor belts or using powerful fans to blow the crushed rock through large pipes. Smaller plants might simply move raw materials around using haul trucks and front-end loaders. Along with the other primary ingredient, clay, limestone is stored in large silos located close to the star of the show: the rotary kiln.
Turning and Burning
A rotary kiln is an enormous tube, up to seven meters in diameter and perhaps 80 m long, set on a slight angle from the horizontal by a series of supports along its length. The supports have bearings built into them that allow the whole assembly to turn slowly, hence the name. The kiln is lined with refractory materials to resist the flames of a burner set in the lower end of the tube. Exhaust gases exit the kiln from the upper end through a riser pipe, which directs the hot gas through a series of preheaters that slowly raise the temperature of the entering raw materials, known as rawmix.
The rotary kiln is the centerpiece of Portland cement production. While hard to see in this photo, the body of the kiln tilts slightly down toward the structure on the left, where the burner enters and finished clinker exits. Source: by nordroden, via Adobe Stock (licensed).
Preheating the rawmix drives off any remaining water before it enters the kiln, and begins the decomposition of limestone into lime, or calcium oxide:
CaCO_{3} \rightarrow CaO + CO_{2}
The rotation of the kiln along with its slight slope results in a slow migration of rawmix down the length of the kiln and into increasingly hotter regions. Different reactions occur as the temperature increases. At the top of the kiln, the 500 °C heat decomposes the clay into silicate and aluminum oxide. Further down, as the heat reaches the 800 °C range, calcium oxide reacts with silicate to form the calcium silicate mineral known as belite:
2CaO + SiO_{2} \rightarrow 2CaO\cdot SiO_{2}
Finally, near the bottom of the kiln, belite and calcium oxide react to form another calcium silicate, alite:
2CaO\cdot SiO_{2} + CaO \rightarrow 3CaO\cdot SiO_{2}
It’s worth noting that cement chemists have a specialized nomenclature for alite, belite, and all the other intermediary phases of Portland cement production. It’s a shorthand that looks similar to standard chemical nomenclature, and while we’re sure it makes things easier for them, it’s somewhat infuriating to outsiders. We’ll stick to standard notation here to make things simpler. It’s also important to note that the aluminates that decomposed from the clay are still present in the rawmix. Even though they’re not shown in these reactions, they’re still critical to the proper curing of the cement.
Portland cement clinker. Each ball is just a couple of centimeters in diameter. Source: مرتضا, Public domain
The final section of the kiln is the hottest, at 1,500 °C. The extreme heat causes the material to sinter, a physical change that partially melts the particles and adheres them together into small, gray lumps called clinker. When the clinker pellets drop from the bottom of the kiln, they are still incandescently hot. Blasts of air that rapidly bring the clinker down to around 100 °C. The exhaust from the clinker cooler joins the kiln exhaust and helps preheat the incoming rawmix charge, while the cooled clinker is mixed with a small amount of gypsum and ground in a ball mill. The fine gray powder is either bagged or piped into bulk containers for shipment by road, rail, or bulk cargo ship.
The Cure
Most cement is shipped to concrete plants, which tend to be much more widely distributed than cement plants due to the perishable nature of the product they produce. True, both plants rely on nearby deposits of easily accessible rock, but where cement requires limestone, the gravel and sand that go into concrete can come from a wide variety of rock types.
Concrete plants quarry massive amounts of rock, crush it to specifications, and stockpile the material until needed. Orders for concrete are fulfilled by mixing gravel and sand in the proper proportions in a mixer housed in a batch house, which is elevated above the ground to allow space for mixer trucks to drive underneath. The batch house operators mix aggregate, sand, and any other admixtures the customer might require, such as plasticizers, retarders, accelerants, or reinforcers like chopped fiberglass, before adding the prescribed amount of cement from storage silos. Water may or may not be added to the mix at this point. If the distance from the concrete plant to the job site is far enough, it may make sense to load the dry mix into the mixer truck and add the water later. But once the water goes into the mix, the clock starts ticking, because the cement begins to cure.
Cement curing is a complex process involving the calcium silicates (alite and belite) in the cement, as well as the aluminate phases. Overall, the calcium silicates are hydrated by the water into a gel-like substance of calcium oxide and silicate. For alite, the reaction is:
Ca_{3}SiO_{5} + H_{2}O \rightarrow CaO\cdot SiO_{2} \cdot H_{2}O + Ca(OH)_{2}
Scanning electron micrograph of cured Portland cement, showing needle-like ettringite and plate-like calcium oxide. Source: US Department of Transportation, Public domain
At the same time, the aluminate phases in the cement are being hydrated and interacting with the gypsum, which prevents early setting by forming a mineral known as ettringite. Without the needle-like ettringite crystals, aluminate ions would adsorb onto alite and block it from hydrating, which would quickly reduce the plasticity of the mix. Ideally, the ettringite crystals interlock with the calcium silicate gel, which binds to the surface of the sand and gravel and locks it into a solid.
Depending on which adjuvants were added to the mix, most concretes begin to lose workability within a few hours of rehydration. Initial curing is generally complete within about 24 hours, but the curing process continues long after the material has solidified. Concrete in this state is referred to as “green,” and continues to gain strength over a period of weeks or even months.
17 thoughts on “Big Chemistry: Cement And Concrete
    1. Also, nice writeup. I wonder about the environmental impact of concrete production; I remember watching a documentary segment years ago about beach erosion due to harvesting of beach sand for concrete. Apparently, desert sand is not great for concrete because it is too small and smooth or something, which means concrete sand mostly comes from beaches and riverbeds.
      1. As a chemistry student , I visited a cement plant in MANGALAGIRI IN Andhra Pradesh in India. It happened to be a question in the final exam. I also remember reading an article about the construction of the HOOVER DAM, and the steps taken to address the
        heat that needed to be tackled over a long period of time. Very interesting article,
        Leo Mallavarapu
      2. The trouble with beach sand is the salt contamination… It weakens the concrete and causes the rebar to corrode quickly. River sand is where it’s at, but there’s precious little of that too.
  1. So yes this is great, but the heating to 1500 is helping climate change a lot. Cement causes globally as much co2 als flying!!!! So we really need to stop using cement a.s.a.p..
    How? That is easy. Cross laminated timber for building multi-level buildings, regular wood skeleton construction for 0 to 3 level buildings (like we have done so for hundreds of years), and for most other purposes we nowadays have a huge variety of lime(stone) which is heated only up to 300 to 400 degrees celcius.
    I rebuilded my house and used 8000 kilo of clay and a few bags of pure limestone to finish all walls floors and ceilings..
    1. So, like freeway overpasses, house foundations, underwater structures, dams, sports stadiums. All made of laminated wood huh? You’re advocating for much more limited lifetime solutions to currently solved problems. Glad the Parthenon wasn’t something like that. Or the Roman colosseum. Lots of examples.
    2. You have a really limited understanding of what concrete is used for if you think wood products can supplant it. And curing limestone requires CO2, a process that takes long enough that it is impractical for cast structural purposes … or for things like highways.
    3. To address the issue of CO2, calcined clay cement can be a solution which is being experimented that will reduce emissions of CO2 during calcination as well as during burning process because calcining clay requires lesser calories
    4. You are right that cement production is producing a lot of CO2 (but not in your easy proposed alternatives /methinks).
      Some of that CO2 comes from carbonates in the rock itself, which offsets nicely with the CO2 the concrete absorbs later. But the other source is fossil natural gas. We need a cleaner way to heat up the furnace to these insane temperatures.
      Perhaps direct solar heating could do it, but that may not be very practical for a plant that usually runs 24h a day. You would need a place with lots of sunshine and a process that can tolerate intermittent heat supply.
      Possibly this would be a good target for green hydrogen, split on site into large stores of hydrogen and oxygen, and available on tap for heating a conventional kiln.
  2. Cement absorbs CO2 during its curing process, a phenomenon known as carbonation. This absorption of CO2 occurs when the concrete reacts with the surrounding atmosphere, leading to the formation of stable carbonates within the concrete structure.
  3. As far as I know, the Colosseum and the remnants of the Port of of Rhodes, have had samples taking and tested. Last I heard, the concrete was passing 90klbs in density and still chemically curing, 2000+years later.
  4. The chemistry of cement and concrete is fascinating, there’s a process which uses supercritical CO2 to cure concrete and form a material that, if I remember and understood correctly, rapidly turns it into limestone with embedded aggregate that’s stronger and more resilient than “normal” concrete.
  5. The ancient Maya used concrete, which had been independently developed in Central America. Unfortunately researching this is heavily polluted by references to “cement” in Mormon scripture which has led to claims that Joseph Smith was aware of pre-Columbian concrete archictecture before it was rediscovered by archaeologists.
    1. Similar reason as to why you can’t find hardly any information about all the swords, armor, and architectural finds on the east coast of the US. (It was initially just a political inconvenience if the native tribes were descendants of a more obviously advanced civilization, so the US Geological Survey purposely destroyed a lot of sites and artifacts in the mid 1800s, before the “Mormon problem” became of any interest to the federal government.)
      This is also why nobody likes to talk about “carborized iron” (steel) swords found in Israel that date to about 600 BC.
Leave a Reply to Cheese WhizCancel reply
