Taking a break from his usual prodding at suspicious AliExpress USB chargers, [DiodeGoneWild] recently had a gander at what used to be a good USB charger.
Before it went completely dead, the Anker 737 GaNPrime USB charger which a viewer sent him was capable of up to 120 Watts combined across its two USB-C and one USB-A outputs. Naturally the charger’s enclosure couldn’t be opened non-destructively, and it turned out to have (soft) potting compound filling up the voids, making it a treat to diagnose. Suffice it to say that these devices are not designed to be repaired.
With it being an autopsy, the unit got broken down into the individual PCBs, with a short detected that eventually got traced down to an IC marked ‘SW3536’, which is one of the ICs that communicates with the connected USB device to negotiate the voltage. With the one IC having shorted, it appears that it rendered the entire charger into an expensive paperweight.
Since the charger was already in pieces, the rest of the circuit and its ICs were also analyzed. Here the gallium nitride (GaN) part was found in the Navitas GaNFast NV6136A FET with integrated gate driver, along with an Infineon CoolGaN IGI60F1414A1L integrated power stage. Unfortunately all of the cool technology was rendered useless by one component developing a short, even if it made for a fascinating look inside one of these very chonky USB chargers.
That was a LOT more complicated than I expected. I’ll never complain about the price of these 120W chargers again. Thankfully I only own a cheap amazonbasics 65W. It feels light
They’re a really smart charger, different voltages on different ports with USB PD per port I think
Just from a quick glance, it looks like the secondary might actually be isolated from line voltage. That’s unusual for these Chinese chargers and makes it worth buying.
Most “Chinese chargers” have an isolated secondary. In fact, I don’t think I have seen one that isn’t. Sure, some I would consider unsafe, but to say that an isolated power supply is “unusual” is just bizarre – the vast majority are flyback based, which by definition is galvanically isolated. Also worth noting that Apple chargers are made in China – are these also “unusual” ?
The myth comes from chargers with unpolarized mains plugs and filter caps between primary neutral and secondary ground.
Most of the time people will stick a DMM between earth and USB ground and see high voltage, but don’t care to check that the short current is tiny.
If you watch Big Clive then you’d see a lot of no-name Chinese electronics that aren’t just bad but deadly bad.
While I agree that you can absolutely find some quality products from China for great prices too, that doesn’t stop there also being a glut of low quality garbage coming from there because of a multitude of reasons.
Its entirely disingenuous to imply that the worry about and bias against Chinese products is entirely based on racism.
For your second half, it makes me concerned you are someone in China Astroturfing. No one would consider Intel, AMD, or NVIDIA chips as being Chinese made because they are from Taiwan. The only people who’d think they are Chinese-made would be someone in China legally required to consider Taiwan part of China.
Usually chargers from companies like Anker, Baseus, or UGreen are quite good. A lot of the other name-brand chargers are also produced in China, but to a high-ish standard.
It’s the cheaper no-name chargers from China that are outright dangerous. Most of the time you can recognize them by being sold under different brand names and all looking the same.
You also pay a bit more for the well-designed chargers. $10 for a 65W GaN charger is unrealistic and suspicious to say the least. ;-)
I have 2 of those 65 watt amazon chargers. They are really solid. I use one with a soldering iron and definitely puts out close to 65 watts and heats up my iron quickly. The other one I use to charge up high capacity LIPO batteries connected to a Lipo charger that I use on my own DIY built drones. They are a great deal.
Why are companies still allowed to produce equipment that can’t be repaired? A single faulty part has rendered the entire PSU in to e-waste.
Sadly, even if it was perfectly repairable – say it literally came with a schematic in the box and philips screws and no potting – it would probably still be 1% or less of users who would repair it or have it repaired.
Heck, I bet 90% of chargers are thrown out intact because of being grungy or in a box in a company storeroom that nobody has the time to test all the gubbins in.
If anything, the world needs “anything not perishable or noxious or unsanitary, to refurbish/reuse by any takers, with no responsibility left to who puts anything in” bins in every recycling station.
Also consider this device is smaller than what would often be considered a spare or wear part you just replace in a vehicle or machine.
I’m not bothered that it has a single point of failure. What consumer electronic can handle an IC failure gracefully? Everything would be too expensive to be designed under the assumption that ICs fail and need redundancy. I’m also not too bothered it’s not repairable though it would be nice.
But the idea of “not trash” bins reminds me of the three Rs: recycle, reduce, reuse. The emphasis today feels like it’s just to recycle. It’s the only option of the three that fits corporate needs for more consumption. But the other two are what will really improve our lives most immediately and we have the most control over.
I’ve always heard it as “reduce, reuse, recycle”, as a prioritized list. Recycling is better than stuff ending up in the landfill, but it should be a last resort.
How much would you pay a repair technician per hour to work on this device, how much are the parts to repair it?
How much did the device cost to buy?
So you would be willing to pay twice the price for something (the additional costs of a design that facilitates repair) that will cost you three time the cost of the original unit to repair? Also, what makes you think enough customers would want that to warrant actually selling it? Companies don’t decide to produce throw-away electronics – their customers do.
All the stuff to make “e-waste” originally came from the ground. If you didn’t make it, you didn’t buy it, and it goes back into the ground, how does it affect you at all?
If you care that much about it, grab a shovel, head to your local landfill, and start a recycling program. If you’re not willing to do that, sit down and be quiet.
Waste is bad and I support banning wasteful practices. Ultimately, because I feel like it.
Nah, I’ll keep talking.
LOL!!!
Wow, I knew education was bad in the US, but this is real peak ignorance.
Automated production is cheap, manual labor to troubleshoot and repair isn’t. Even on a device that’s easily taken apart with no potting, it’s easy for a repair to cost twice as much as buying a new unit. Making repairs possible isn’t too hard, making repairs cheap enough that the devices actually get fixed is much harder.
The potting resin is a good idea in this case, compact chargers like this are physically thrown around and impacted all the time, you don’t want those heavy inductors and capacitors flapping in the breeze.
I have to imagine that the potting also helps conduct heat out of the unit better than if it were filled with air.
Also probably more isolating than air.
Only between components above the traces. Potting or coating does NOT allow to reduce isolation distances in the layout. (as per standards)
The transformer was interesting, and it was nice that he investigated it and showed the cutout.
As for waste, I wonder if that transformer is reusable if you carefully separate it, since it’s on a separate PCB.
I know DGW uses old parts and at least he got some capacitors and maybe some USB ports from it.
These transformers are very specific to this particular implementation. The PCB would only be useful if you are building pretty much the same SMPS.
Transformers in such devices are all very similar surely, you have a primary a secondary and sometimes the sense/boot winding, and since this is for a 120W supply I would think there is headroom.
It has an air-gap of course, but we know that.
And you can measure its inductance and resistance to find out its ratings.
Not that I’m an expert, but I think DGW for instance is very knowledgeable on the subject and he comes up with some original homemade stuff, who knows what he could do with such.
You perhaps could at least make one of those LED lights activated by QI coils from it after you remove the ferrite as he did :)
In other words, a fully functional power supply for custom voltages is rendered useless because the voltages must be digitally negotiated by the device? I remember discussions not long ago where this was said to be an advantage of USB…
Like your bench power supply, relying on the knobs to be useful…
my bench power supply has pots I can replace even without soldering
An all new definition of the word useless was born.
What’s with people’s instance of ruining words these days?
It’s a USB PD charger functioning as such, and is in fact in modern times more useful than a general PSU for most people since it can charge… wait for it… USB-C devices!!
And you can incidentally buy small PD trigger boards to turn it into a power supply with selectable voltages.
Sure, the USB-C charger is useful for USB-C devices, but the problem with USB PD is that you can’t use it without the negotiation magic even if you happen to have the right voltage at hand, which would be no issue if the digital negotiation was not made mandatory (there are other means for voltage selection or ensuring the right voltage is supplied which are much more repairable and rugged, and which could have been used in a power supply standard).
This is just an example for a fault mentioned in the lengthy discussions around USB PD, which was claimed to never be a problem by the proponents.
Look, there is a reason for the negotiation with USB, and that is because of the connector used.
You can’t have it all at the same time, that is to say a relatively thin cable and tiny connector and very high speed data and high power and trust it all works without issues with the devices (source and drain) being dumb.
Interestingly even in SciFi movies and TV shows where the often take extreme liberties with the laws of physics they don’t have such. I at least don’t recall seeing them use a USB-c sized connector to deliver any high power, they always have props with bigger connectors right?
I wonder if anybody minds having heavy elements and poisons in their groundwater, I’m sure not, it doesn’t affect them after all, nor their children. Don’t believe me? Ask RunnerPack about it.
People are so silly now’days, in the 1970’s there was tons of lead in the air and nobody had an issue, now you see people complain if as much as 33 grams enters their body, geez.
WHAT THE F[censored for HaD kids of average age 55..]
Is there some AI involved putting comments in random reply positions and avoiding putting it where a person is replying to? If so it’s eerily advanced.
Maybe that AI was retrieved from an alien weapon that crashed ! :o
That seems a rather vicious reaction to a single instance of an issue.
And issue that might even be on your side, just because it used to work doesn’t mean your phone didn’t develop issues, or you might be in area where there are lots of interference signals or something. Or maybe the shop you bought it at was selling recalled/returned/defective items.
That last one was a reply to Andrew Davis’s post
Thanks HaD-bama ;)
Anker used to make some good stuff, but lately they have had loads of problems. I used to use their neckband ear bud head phones, but the latest version has a software issue that causes connection issues, fought with them for a while and they said it was my phone. but the previous version worked just fine. after 3 replacements they basically told me to f*ck off.
Still haven’t found a brand that was as good as they USED to be, but dealing. Won’t ever buy that brand again EVER!
The right to repair is not always about the price tag, it’s also about the environmental cost of assuming everything is disposable
