The original DOOM is famously portable — any computer made within at least the last two decades, including those in printers, heart monitors, passenger vehicles, and routers is almost guaranteed to have a port of the iconic 1993 shooter. The more modern iterations in the series are a little trickier to port, though. Multi-core processors, discrete graphics cards, and gigabytes of memory are generally needed, and it’ll be a long time before something like an off-the-shelf router has all of these components.
But with a specialized distribution of Debian Linux called Proxmox and a healthy amount of configuration it’s possible to flip this idea on its head: getting a desktop computer capable of playing modern video games to take over the network infrastructure for a LAN instead, all with minimal impact to the overall desktop experience. In effect, it’s possible to have a router that can not only play DOOM but play 2020’s DOOM Eternal, likely with hardware most of us already have on hand.
The key that makes a setup like this work is virtualization. Although modern software makes it seem otherwise, not every piece of software needs an eight-core processor and 32 GB of memory. With that in mind, virtualization software splits modern multi-core processors into groups which can act as if they are independent computers. These virtual computers or virtual machines (VMs) can directly utilize not only groups or single processor cores independently, but reserved portions of memory as well as other hardware like peripherals and disk drives.
Proxmox itself is a version of Debian with a number of tools available that streamline this process, and it installs on PCs in essentially the same way as any other Linux distribution would. Once installed, tools like LXC for containerization, KVM for full-fledged virtual machines, and an intuitive web interface are easily accessed by the user to allow containers and VMs to be quickly set up, deployed, backed up, removed, and even sent to other Proxmox installations.
Desktop to Server
The hardware I’m using for Proxmox is one of two desktop computers that I put together shortly after writing this article. Originally this one was set up as a gaming rig and general-purpose desktop computer running Debian, but with its hardware slowly aging and my router not getting a software update for the last half decade I thought I would just relegate the over-powered ninth-generation Intel Core i7 with 32 GB of RAM to run the OPNsense router operating system on bare metal, while building a more modern desktop to replace it. This was both expensive not only in actual cost but in computer resources as well, so I began investigating ways that I could more efficiently use this aging desktop’s resources. This is where Proxmox comes in.
By installing Proxmox and then allocating four of my eight cores to an OPNsense virtual machine, in theory the desktop could function as a router while having resources leftover for other uses, like demon-slaying. Luckily my motherboard already has two network interfaces, so the connection to a modem and the second out to a LAN could both be accommodated without needing to purchase and install more hardware. But this is where Proxmox’s virtualization tools start to shine. Not only can processor cores and chunks of memory be passed through to VMs directly, but other hardware can be sectioned off and passed through as well.
So I assigned one network card to pass straight through to OPNsense, which connects to my modem and receives an IP address from my ISP like a normal router would. The other network interface stays with the Proxmox host, where it is assigned to an internal network bridge where other VMs get network access. With this setup, all VMs and containers I create on the Proxmox machine can access the LAN through the bridge, and since the second networking card is assigned to this bridge as well, any other physical machines (including my WiFi access point) can access this LAN too.
Not All VMs are Equal
Another excellent virtualization feature that Proxmox makes easily accessible is the idea of “CPU units”. In my setup, having four cores available for a router might seem like overkill, and indeed it is until my network gets fully upgraded to 10 Gigabit Ethernet. Until then, it might seem like these cores are wasted.
However, using CPU units the Proxmox host can assign unused or underutilized cores to other machines on the fly. This also lets a user “over-assign” cores, while the CPU units value acts as a sort of priority list. My ninth-generation Intel Core i7 has eight cores, so in this simple setup I can assign four cores to OPNsense with a very high value for CPU units and then assign six cores to a Debian 12 VM with a lower CPU unit value. This scheduling trick makes it seem as though my eight-core machine is actually a ten-core machine, where the Debian 12 VM can use all six cores unless the OPNsense VM needs them. However, this won’t get around the physical eight-core reality where doing something like playing a resource-intense video game while there’s a large network load, and this reassignment of cores back to the router’s VM could certainly impact performance in-game.
Of course, if I’m going to install DOOM Eternal on my Debian 12 VM, it’s going to need a graphics card and some peripherals as well. Passing through USB devices like a mouse and keyboard is straightforward. Passing through a graphics card isn’t much different, with some caveats.
The motherboard, chipset, and processor must support IOMMU to start. From there, hardware that’s passed through to a VM won’t be available to anything else including the host, so with the graphics card assigned to a VM, the display for the host won’t be available anymore. This can be a problem if something goes wrong with the Proxmox machine and the network at the same time (not out of the question since the router is running in Proxmox too), rendering both the display and the web UI unavailable simultaneously.
To mitigate this, I went into the UEFI settings for the motherboard and set the default display to the integrated Intel graphics card on the i7. When Proxmox boots it’ll grab the integrated graphics card, saving the powerful Radeon card for whichever VM needs it.
At this point I’ve solved my initial set of problems, and effectively have a router that can also play many modern PC games. Most importantly, I haven’t actually spent any money at this point either. But with the ability to over-assign processor cores as well as arbitrarily passing through bits of the computer to various VMs, there’s plenty more that I found for this machine to do besides these two tasks.
Containerized Applications
The ninth-gen Intel isn’t the only machine I have from this era. I also have an eighth-generation machine (with the IME disabled) that had been performing some server duties for me, including network-attached storage (NAS) and media streaming, as well as monitoring an IP security camera system. With my more powerful desktop ready for more VMs I slowly started migrating these services over to Proxmox, freeing the eighth-gen machine for bare-metal tasks largely related to gaming and media. The first thing to migrate was my NAS. Rather than have Debian manage a RAID array and share it over the network on its own, I used Proxmox to spin up a TrueNAS Scale VM. TrueNAS has the benefit of using ZFS as a filesystem, a much more robust setup than the standard ext4 filesystem I use in most of my other Linux installations. I installed two drives in the Proxmox machine, passed them through to this new VM, and then set up my new NAS with a mirrored configuration, making this NAS even more robust than it previously was under Debian.
The next thing to move over were some of my containerized applications. Proxmox doesn’t only support VMs, it has the ability to spin up LXC containers as well. Containers are similar to VMs in that the software they run is isolated from the rest of the machine, but instead of running their own operating system they share the host’s kernel, taking up much less system resources. Proxmox still allows containers to be assigned processor cores and uses the CPU unit priority system as well, so for high-availability containers like Pihole I can assign the same number of CPU units as my OPNsense VM, but for my LXC container running Jelu (book tracking), Navidrome (streaming music), and Vikunja (task lists), I can assign a lower CPU unit value as well as only one or two cores.
The final containerized application I use is Zoneminder, which keeps an eye on a few security cameras at my house. It needs a bit more system resources than any of these other two, and it also gets its own hard drive assigned for storing recordings. Unlike TrueNAS, though, the hard drive isn’t passed through but rather the container mounts a partition that the Proxmox host retains ultimate control over. This allows other containers to see and use it as well.
At this point my Proxmox setup has gotten quite complex for a layperson such as myself, with a hardware or system failure meaning that not only would I lose my desktop computer but also essentially all of my home’s network infrastructure and potentially all of my data as well. But Proxmox also makes keeping backups easy, a system that has saved me many times.
For example, OPNsense once inexplicably failed to boot, and another time a kernel update in TrueNAS Scale caused it to kernel panic on boot. In both cases I was able to simply revert to a prior backup. I have backups scheduled for all of my VMs and containers once a week, and this has saved me many headaches. Of course, it’s handy to have a second computer or external drive for backups, as you wouldn’t want to store them on your virtualized NAS which might end up being the very thing you need to restore.
I do have one final VM to mention too, which is a Windows 10 installation. I essentially spun this up because I was having an impossibly difficult time getting my original version of Starcraft running in Debian and thought that it might be easier on a Windows machine. Proxmox makes it extremely easy to assign a few processor cores and some memory and test something like this out, and it turned to work out incredibly well.
So well, in fact, that I also installed BOINC in the Windows VM and now generally leave this running all the time to take advantage of any underutilized cores on this machine for the greater good when they’re not otherwise in use. BOINC is also notoriously difficult to get running in Debian, especially for those using non-Nvidia GPUs, so at least while Windows 10 is still supported I’ll probably keep this setup going for the long term.
Room for Improvement
There are a few downsides to a Proxmox installation, though. As I mentioned previously, it’s probably not the best practice to keep backups on the same hardware, so if it’s your only physical computer then that’ll take some extra thought. I’ve also had considerable difficulty passing an optical drive through to VMs, which is not nearly as straightforward as passing through other hardware types for reasons which escape me. Additionally, some software doesn’t take well to running on virtualized hardware at all. In the past I have experimented with XMR mining software as a way to benchmark hardware capabilities, and although I never let it run nearly long enough to ever actually mine anything it absolutely will not run at all in a virtualized environment. There are certainly other pieces of software that are similar.
I also had a problem that took a while to solve regarding memory use. Memory can be over-assigned like processor cores, but an important note is that if Proxmox is using ZFS for its storage, as mine does, the host OS will use up an incredibly large amount of memory. In my case, file transfers to or from my TrueNAS VM were causing out-of-memory issues on some of my other VMs, leading to their abrupt termination. I still don’t fully understand this problem and as such it took a bit of time to solve, but I eventually both limited the memory the host was able to use for ZFS as well as doubled the physical memory to 64 GB. This had the downstream effect of improving the performance of my other VMs and containers as well, so it was a win-win at a very minimal cost.
The major downside for most, though, will be gaming. While it’s fully possible to run a respectable gaming rig with a setup similar to mine and play essentially any modern game available, this is only going to work out if none of those games use kernel-level anticheat. Valorant, Fortnite, and Call of Duty are all examples that are likely to either not run at all on a virtualized computer or to get an account flagged for cheating.
There are a number of problems with kernel-level anti-cheat including arguments that they are types of rootkits, that they are attempts to stifle Linux gaming, and that they’re lazy solutions to problems that could easily be solved in other ways, but the fact remains that these games will have to be played on bare metal. Personally I’d just as soon not play them at all for any and all of these reasons, even on non-virtualized machines.
Beat On, Against the Current
The only other thing worth noting is that while Proxmox is free and open-source, there are paid enterprise subscription options available, and it is a bit annoying about reminding the user that this option is available. But that’s minor in the grand scheme of things. For me, the benefits far outweigh these downsides. In fact, I’ve found that using Proxmox has reinvigorated my PC hobby in a new way.
While restoring old Apple laptops is one thing, Proxmox has given me a much deeper understanding of computing hardware in general, as well as made it easy to experiment and fiddle with different pieces of software without worrying that I’ll break my entire system. In a very real way it feels like if I want a new computer, it lets me simply create a virtual one that I am free to experiment with and then throw away if I wish. It also makes fixing mistakes easy. Additionally, most things running on my Proxmox install are more stable, more secure, and make more efficient use of system resources.
It’s saved me a ton of money since I nether had to buy individual machines like routers or a NAS and its drives too, nor have I had to build a brand new gaming computer. In fact, the only money I spent on this was an arguably optional 32 GB memory upgrade, which is pennies compared to having to build a brand new desktop. With all that in mind, I’d recommend experimenting with Proxmox for anyone with a computer or similarly flagging interest in their PC in general, especially if they still occasionally want to rip and tear.
What about using it to run Minecraft? Can it deal with 4-5 players at once? Minecraft is a good game for brain development because it stimulates imagination and constructive thinking.
I’m sure it could do some Minecrafting; part of my original plan for this machine was to set up a VM that could host Steam Remote Play for some of my underpowered laptops. I dropped this idea eventually due to lack of system resources once all of my more important services were migrated to the machine, and also due to a very bad decision I made to only install a 500 GB drive in this computer, making it somewhat difficult to install more than one game at a time since so much drive space is devoted to other VMs. The VM I run DOOM in only has around 120 GB, for example.
If you have the hardware, though, you should give a virtualized Minecraft server a shot!
Nice intro to proxmox, which I keep wondering about when I frequently see it mentioned in the comments here or on slashdot. Seems like an odd use-case though, dedicating a chunk of a beastly desktop PC to being a router. Just spent $100-150 on a fanless low power mini-pc with multiple ethernet ports and stick Debian on that to be your router (or your preferred gui based router os if you’re feeling lazy).
I attempted to do this with my (rather aging, somewhat ship-of-theseus’d) gaming PC a while ago, and ran into problems with GPU passthrough that ended up just being that my motherboard didn’t support any GPU passthrough to VMs. Check your compatibility before you go down this rabbit hole.
Handy for joining the Fediverse.
Doom and Linux, the two greatest tragedies of the 90s IMHO! In same sentences! You’re killing me! Haha!🤣🤣🤣🥲
Doom and Linux, far behind the success of Windows as far as tragedies go.
I’m not a Windows fanboy by any means, either.
If it was me, then Windows 3.1x or WfW could have been the final release.
OS/2 2.x and up had Windows 3.x built-in, after all, so a future with OS/2 wouldn’t have been a terrible loss, either.
What’s sad about Doom and Linux, though, I think, is that they’ve sort of ended the era of point&click adventure games and DOS software.
Or did it more quickly, maybe. Depends on point of view.
The cultural, intellectual side of computing in the 90s, so to say.
It’s often Linux fans who’re promoting Doom and other shooters, I think.
It’s probably also related to mental state, a matter of the level of being infantile and so on.
But that’s just my opinion or observation, no offense.
And while we’re at it, both Doom and Linux relied on quick&cheap 32-Bit flat-mode.
It’s another negative side, I think. Doom made DOS/4GW extender even more popular.
In terms of stability, segmented memory or at least use of full x86 ring scheme would have been more responsible.
But Linux being portable didn’t utilize it, either.
Again, that’s where OS/2 was doing it slightly better, I think. It was made for x86.
While it also didn’t utilize segmentation for 32-Bit code anymore,
it did at least contain legacy code in sensible spots and had used full ring scheme of the 80386.
Users of an 80286 PC could program fine 16-Bit OS/2 1.3 applications that ran even better on OS/2 2.x and Warp.
But again, that’s just me. I don’t think that either Doom or Linux were anyhow outstanding.
If at all, they were for being a manifest of human stupidity. In my opinion only, of course.
My number one blocker from switching to VM based main machine is the issues with GPU passthrough.
If only they could make using a GPU in multiple VMs and the host as simple as with the CPU or RAM with over provisioning so I could use 100% of my GPU in a game in a VM then swap to a different VM to run an AI, or run split loads.
If I could do all that then I’d swap over immediately so I could isolate things easier. As it stands if I wanted to run a game with Kernal Anti-Cheat with the reasonable desire that it not be able to actually spy on absolutely all my stuff then I’m SOL without some major retooling to swap GPU hosts or swapping drives and rebooting to an entirely different OS for some things.
Be warry of virtualizing everything. You turn the host into a single point of failure. I have an old server running a few VMs. It has 4 network ports so I considered virtualizing my router but decided against it. Later I had some issues with the server that took a few hours to fix, no big deal, but it would have been a much bigger headache for me and my household if the internet had been down the whole time because our virtual router was unavailable.
I do still have my old Asus router sitting on my shelf, so in an emergency I can just disconnect the desktop and hook up that router to get the network functioning again. This has actually happened at least once since I started using Proxmox. But in the meantime it and its old firmware can stay unplugged.
One thing I didn’t get into much in the article is that Proxmox supports nodes to replicate VMs and containers for high-availability across more than one computer, so if you have multiple physical machines you can duplicate VMs across them. This eliminates the single point of failure so if one machine shuts down the others can pick it up immediately. Of course this has an added cost of another machine, but it is a possibility which solves this problem.
I certainly wouldn’t play video games on the same hardware that is the router at my workplace or any serious business.
But for home use… ok I guess. Years ago my home email/web/file server, router and desktop were all one machine. Actually.. my first router was a Windows 98 computer that also served as a desktop for anyone who wanted to browse or use instant messenger while hanging out in my college apartment livingroom!
But I never really got the whole virtualization craze. I mean… I can see it I guess for high-availability commercial environments where you might take one node down at a time for upgrades and maintenance. But at home?
The Linux Kernel is great at multitasking. Being a router AND being Doom at the same time shouldn’t be any challenge. Splitting everything up into VMs just means more overhead and more to maintain.
That concept isn’t so new, actually.
Way back in the 1980s users ran BBS software on their Amiga or DOS PC, while playing some games or using it for productivity software.
Amiga had great multitasking built-in into the OS, while DOS users ran DESQView or one of the multitasking DOSes.
With advent of OS/2 2.x, it even got better on the PC side.
Multitasking was so good that multiple copies of the BBS software could be run, each for one modem/user.
Also interesting, also from the 80s..
“There was also a Merge/286 version that ran on an unmodified PC/AT (without any special I/O trapping hardware);
it ran as long as the PC program was reasonably well-behaved,
though a malicious or crashing program could take the unprotected UNIX kernel down on those machines.
Even so, the notoriously ill-behaved Microsoft Flight Simulator would run on the PC/AT simultaneously with Unix.”
https://en.wikipedia.org/wiki/Merge_(software)
It’s notable that gaming was possible in a VM running on 16-Bit Unix on 80286 (!), years before Linux had even existed.
this was a real head scratcher for me. i mean, i love virtualization…i use it for genuinely weird platforms (like running a 20 year old version of 32-bit x86 debian), and just for convenience i use it these days to let my browser run with exactly the runtime libraries it expects instead of the ones that are shared with everything else. i use qemu to emulate some non-pc hardware.
but routers are nothing. my primary pc has eventually evolved into a headless basement server but for 30 years straight it has been my router in addition to picking up whatever random load, whether it be media player or videogames or whatever. you absolutely do not need virtualization, containerization, or anything like that to get a linux machine to route packets. for any ‘soho’ sort of environment it’s basically impossible to even detect the cpu load of routing a whole house’s network. vpn, nat, firewall, qos, ipsec, whatever.
but then i read the words ‘router operating system’ and i realized it’s just that side of containerization. where people take regular functions of regular OSes and decide to make a whole OS image ‘dedicated’ to that task. so far as i can tell, there’s absolutely no reason to do it that way. there’s nothing exotic under the sun anymore and a stock debian installation can do everything.
but now that virtualization is so cheap i guess there’s no reason not to do it that way. instead of distributing like a graphical front end to a few scripts that run on stock debian, why not do the exact same thing but declare that it’s a “router operating system” and can’t do anything else. i don’t like it i have to admit it’s fine…every app can be a container.
i bought the $150 temu laptop and i love it but i still can’t quite wrap my mind around 8GB of RAM in a $150 laptop. there is absolutely no call for it in my life and yet here it is, so much RAM i might as well run every single program in a container with its own copy of the kernel and everything else. no reason not to.
Have you considered using incus https://linuxcontainers.org/incus/?
It’s the official container/vm manager from the LXC team. Proxmox also uses LXC container technology.
