Linear Actuators 101
A set of three linear actuators set atop a green with yellow grid cutting mat. The electric actuator on the top of the image is silver and has a squarish tube. It is slender compared to the other two. A black, hydraulic actuator sits in the middle and is the largest of the three. A silver pneumatic actuator at the bottom of the image is the middle sized unit.
Linear actuators are a great help when you’re moving something along a single axis, but with so many options, how do you decide? [Jeremy Fielding] walks us through some of the high level tradeoffs of using one type of actuator over another.
There are three main types of linear actuator available to the maker: hydraulic, pneumatic, and electric. Both the hydraulic and pneumatic types move a cylinder with an attached rod through a tube using pressure applied to either side of the cylinder. [Fielding] explains how the pushing force will be greater than the pulling force on these actuators since the rod reduces the available surface area on the cylinder when pulling the rod back into the actuator.
Electric actuators typically use an electric motor to drive a screw that moves the rod in and out. Unsurprisingly, the electric actuator is quieter and more precise than its fluid-driven counterparts. Pneumatic wins out when you want something fast and without a mess if a leak happens. Hydraulics can be driven to higher pressures and are typically best when power is the primary concern which is why we see them in construction equipment.
You can DIY your own linear actuators, we’ve seen tubular stepper motors, and even a linear actuator inspired by muscles.
16 thoughts on “Linear Actuators 101
  1. “Unsurprisingly, the electric actuator is quieter and more precise than its fluid-driven counterparts.”
    High end systems with Hydraulic cylinders can be engineered for high precision, achieving positional accuracy down to ±0.01mm. Commercial linear feedback cylinders positional accuracy typically ranges from +/- 0.5 mm for basic systems to +/- 0.1 mm or better for advanced smart cylinders
        1. I chose to believe LordNothing really meant Osculate, and that his device kisses his lonely friend on each cheeks, back and forth, from 5-6 inches at a reasonable speed (indeed) to cheer him up.
  2. Is electro-magnetic also a class of linear actuator? One of my earlier jobs was the care and operation of an IBM 5224 shuttle-matrix printer. The field tech gave me a couple of worn-out items when he repaired the printer. It’s a small electromagnet that “fires” the pin outwards by about 1 or 2mm. He said you actuate it by applying 12VDC but only for very brief periods. Anything more than 1 or 2 seconds at a time would burn it out.
    1. that just sounds like a small solenoid
      If you want to checkout a better class of electromagnetic linear actuator look into linear voice coil motors. With proper drivers and sensors they can reach sub-micrometer (nanometer) levels while having stroke lengths up to 8 inches. Depending on its size, model, and operating current, They can exert varying forces ranging from less than 1 Newton (N) to over 1300 N (300 lbs).
      1. Almost forgot to mention that they are exceptionally fast, capable of speeds exceeding 1 m/s, with some systems achieving speeds of over 750 mm/s (0.75 m/s), even faster for specialized applications like high-frequency sinusoidal motion.
  3. lol I knew as soon as I read the title,this is gonna be fun… the problem is that our brain is already wired that way, so moving on, I managed to drive one at 16 miliseconds forward, disconnect 500 miliseconds and go backwards another 16 miliseconds and a pot to adjust from there. thanks me later! :)
Leave a Reply to Tony MCancel reply
