2025 Component Abuse Challenge: Pushing A 555 To The Limit
The humble 555 timer has its origins back in the early 1970s as the NE555, a bipolar integrated circuit. Over the years it has spawned a range of derivatives, including dual versions, and ones using CMOS technology. Have these enhancements improved the performance of the chip significantly? [MagicWolfi] has been pushing the envelope in an effort to see just how fast an astable 555 can be.
The Microchip MIC1555 may be the newest of the bunch, a 5-pin CMOS SOT-23 which has lost the frequency control and discharge pins of the original. It’s scarcely less versatile though, and it’s a fine candidate for an oscillator to push. We see it at a range of values for the capacitor and resistor in an astable configuration, each of which is tested across the supply voltage range. It’s rated as having a maximum frequency of 5 MHz, but with a zero Ohm resistor and only the parasitic capacitance of an open circuit, it reaches the giddy heights of 9.75 MHz. If we’re honest we find this surprising, but on reflection the chip would never be a first choice for super-fast operation.
We like it that someone’s managed to tie in the 555 to the contest, and given that it still has a few days to run at the time of writing, we’re hoping some of you might be inspired to enter one of your own.
5 thoughts on “2025 Component Abuse Challenge: Pushing A 555 To The Limit
  1. I second Eric’s quad 555s. Grabbed a few when it was still possible to get out of Shenzhen for cheap, and, surprisingly, even these suspicious clones proved to be useful (then again, my R&D amateur projects most of the times have the tolerances the width of Atlantic Pond : – ]).
    Also, missing 555s in a metal can; heluva easier to solder and can be stuck/added just about anywhere and metal casing adds shielding. Perhaps there is small but steady demand for those SOTs encased just so, long copper leads and all.
  2. I designed a simple 555-like circuit in 90nm cmos just for fun. It had a very simple comparator, a std cell based rs-latch. It had the cheat (advantage) of having the resistors and capacitor on “chip”. It could run at 1Ghz. I didn’t figure out how much the performance would have degraded with off chip R’s and C. (I used to design process monitors for a fabless company)
Leave a Reply to AknupCancel reply
