The Value Of A Worked Example
I was looking over the week’s posts on Hackaday – it’s part of my job after all – and this gem caught my eye: a post about how to make your own RP2040 development board from scratch. And I’ll admit that my first thought was “why would you ever want to do that?” (Not a very Hackaday-appropriate question, honestly.) The end result will certainly cost more than just buying a Pi Pico off the shelf!
Then it hit me: this isn’t a project per se, but rather [Kai] was using it as an test run to learn the PCB-production toolchain. And for that, replicating a Pico board is perfect, because the schematics are easily available. While I definitely think that a project like this is a bit complicated for a first PCB project – I’d recommend making something fun like an SAO – the advantage of making something slightly more involved is that you run into all of the accompanying problems learning experiences. What a marvelous post-complete-beginner finger exercise!
And then it hit me again. [Kai]’s documentation of everything learned during the project was absolutely brilliant. It’s part KiCAD tutorial, part journal about all the hurdles of getting a PCB made, and just chock-full of helpful tips along the way. The quality of the write-up turns it from being just a personal project into something that can help other people who are in exactly the same boat, and I’m guessing that’s a number of you out there.
In the end, this was a perfect Hackaday project. Yes, it was “too simple” for those who have made their 30th PCB design. (Although I’d bet you could still pick up a KiCAD tip or two.) And yes, it doesn’t make economic sense to replicate mass-market devices in one-off. And of course, it doesn’t need that fun art on the board either. But wrap all these up together, and you get a superbly documented guide to a useful project that would walk you through 95% of what you’ll need to make more elaborate projects later on. Superb!
Surely you do “finger exercises” too. Why not write them up, and share the learning? And send them our way – we know just the audience who will want to read it.
3 thoughts on “The Value Of A Worked Example
  1. That’s what you’re supposed to do if you intend to actually make something out of the RP2040. The development board is nothing but a minimal reference implementation, which you can then expand upon or remove from, depending on your needs. Knowing how to replicate the development board means you know how to adapt the chip into a product.
    Unless you’re one of those people who stuff Arduinos and other development boards into products as is, pay the extra cost to the middle man, and live with the fact that it’s a product outside of your control, not built or sold for your purpose in the first place, and may vanish from the market at any time.
  2. Hold on …
    Isn’t that almost literally 90% of these projects?
    Doesn’t every project start as:
    I want to learn 25 more skills this year and make something with them so I have experience. And this project could cover 4 skills so that’s what I’m doing.
    If that’s not how you have been looking at HaD projects, then I don’t actually understand.
    Different backgrounds and view points I guess. But I figured our fundamentals would be similar.
Leave a Reply to DudeCancel reply
