Casting Metal Tools With Kitchen Appliances
Perhaps the biggest hurdle to starting a home blacksmithing operating is the forge. There’s really no way around having a forge; somehow the metal has to get hot enough to work. Although we might be imagining huge charcoal- or gas-fired monstrosities, [Shake the Future] has figured out how to use an unmodified, standard microwave oven to get iron hot enough to melt and is using it in his latest video to cast real, working tools with it. (Also available to view on Reddit)
In the past, [Shake the Future] has made a few other things with this setup like an aluminum pencil with a graphite core. This time, though, he’s stepping up the complexity a bit with a working tool. He’s decided to build a miniature bench vice, which uses a screw to move the jaws. He didn’t cast the screw, instead using a standard size screw and nut, but did cast the two other parts of the vice. He first 3D prints the parts in order to make a mold that will withstand the high temperatures of the molten metal. With the mold made he can heat up the iron in the microwave and then pour it, and then with some finish work he has a working tool on his hands.
A microwave isn’t the only kitchen appliance [Shake the Future] has repurposed for his small metalworking shop. He also uses a standard air fryer in order to dry parts quickly. He works almost entirely from the balcony of his apartment so he needs to keep his neighbors in mind while working, and occasionally goes to a nearby parking garage when he has to do something noisy. It’s impressive to see what can be built in such a small space, though. For some of his other work be sure to check out how he makes the crucibles meant for his microwave.
23 thoughts on “Casting Metal Tools With Kitchen Appliances
  1. He also does some clever stuff with vacuum assist casting, repurposing a table and a shopvac, which really helps the casting detail. I’ve been imitating his work and happily melting copper and cast iron in a microwave I got for free because it was broken. He’s put years of work into refining his workflow and really has an impressive toolchain now. It can’t handle the volume that my propane fired foundry can melt, but for small batches, it is surprisingly fast compared to a massive cast refractory furnace. Like 8 minutes to have copper ready to pour.
      1. When you wrote “liberated the transformers from the…” I could not help hearing the theme sone of that famous animation show: “Transformers… more than meets the eye”. Then I read further and noticed it were not the kind of transformers you were referring to.
  2. I had no idea this was possible. This guy is off the charts creative and I like his demeanor. Now I have to see what it takes to melt metal in a microwave. I see a lot of home made equipment. It’s clear he didn’t stumble on this technique overnight. What a gem. I wonder what other metals you can melt?
    1. Thanks, I was coming here to point this out.
      Blacksmithing works with iron & steel in the plastic state, not liquid.
      That doesn’t undermine how cool this is, boy it’s a different thing
Leave a Reply to LukaszCancel reply
