Warnings About Retrobright Damaging Plastics After 10 Year Test
Within the retro computing community there exists a lot of controversy about so-called ‘retrobrighting’, which involves methods that seeks to reverse the yellowing that many plastics suffer over time. While some are all in on this practice that restores yellow plastics to their previous white luster, others actively warn against it after bad experiences, such as [Tech Tangents] in a recent video.
Uneven yellowing on North American SNES console. (Credit: Vintage Computing)
After a decade of trying out various retrobrighting methods, he found for example that a Sega Dreamcast shell which he treated with hydrogen peroxide ten years ago actually yellowed faster than the untreated plastic right beside it. Similarly, the use of ozone as another way to achieve the oxidation of the brominated flame retardants that are said to underlie the yellowing was also attempted, with highly dubious results.
While streaking after retrobrighting with hydrogen peroxide can be attributed to an uneven application of the compound, there are many reports of the treatment damaging the plastics and making it brittle. Considering the uneven yellowing of e.g. Super Nintendo consoles, the cause of the yellowing is also not just photo-oxidation caused by UV exposure, but seems to be related to heat exposure and the exact amount of flame retardants mixed in with the plastic, as well as potentially general degradation of the plastic’s polymers.
Pending more research on the topic, the use of retrobrighting should perhaps not be banished completely. But considering the damage that we may be doing to potentially historical artifacts, it would behoove us to at least take a step or two back and consider the urgency of retrobrighting today instead of in the future with a better understanding of the implications.
7 thoughts on “Warnings About Retrobright Damaging Plastics After 10 Year Test
  1. At the heart of the issue lies the misconception that all plastics are alike, and what damages one damages all. This is not so: there are plastics that go brittle on their on, while others don’t; there are plastics that are negatively affected by retr0bright while others ain’t. Treating the problem as if the plastics of a Dreamcast behave in the same way as the plastics on a SNES is not the way to look at these problems.
  2. I would consider a multi part treatment. Strong oxidants can remove discoloration but they probably create many acidic sites which can later easily yellow. So you probably need to esterify them or something similar. Perhaps cost them in an antioxidant after. Not sure but in most cases oxidants are used to age materials not the opposite!
  3. I have an SNES as yellow as the one in the post, and it is already extremely brittle. I also have an SNES Jr that was not that yellow, which I retr0brited a couple of years ago, which is still just as solid as ever. I think the brittleness is just due to age and specific chemical makeup of the original plastic. I would definitely assume that a Sega console from just before they shut down their hardware development would have more corners cut than a Nintendo product.
    1. I forgot to mention: I use standard drugstore 3% H2O2, not the stronger hair bleach type, but I have a fairly powerful UV source, originally designed to cure sealants for automotive applications, which I use in short bursts. The only bad thing that happened was when I accidentally forgot about my SNES mouse shell, which is now bleached almost white. It is still not brittle, however.
  4. It’s not entirely a surprise that this is a problem, you’re not stopping or reversing the ageing process, you’re just masking the symptoms.
    Like a fine coating of rust on steel is often left untreated because it prevents further, more significant corrosion forming, I suspect retrobrighting exposes fresh surface to damage.
    Personally, I prefer ‘patina’ and just don’t bother doing anything other than cleaning the accumulated crud off of old stuff with warm water and dish soap, if it’s really unpleasant I might run it through a low temperature dishwasher cycle (works great for getting rid of accumulated crud on circuit boards and also cleans off the rosin flux that was applied to old HiFi and radio gear)
Leave a Reply to ImanCancel reply
