Build Yourself A Graphing Weather Display
These days, Internet connectivity is ubiquitous, so you can look up live weather data on just about any device around you. Regardless, [Jozerworx] wanted a simple, clean, independent weather display, and came up with this simple design.
The build is based on the Lilygo T5 EPD devboard, which combines an ESP32-S3 microcontroller with a nice 4.7-inch e-paper display. This display has the benefit that it only uses power when it’s being updated, making it particularly suitable to run off a battery for extended periods of time. Meanwhile, the ESP32 and its inbuilt Wi-Fi connectivity allow it to query the internet for updated weather forecasts. Weather data is sourced via the OpenWeather API, which [Jozerworx] notes comes with the caveat of requiring an API key. It’s a little fussy, but if you want good weather data, there are few easier ways to get it. The display shows a forecast for the next five days, while also showing graphs of ambient temperature and humidity along with useful information like the sunset and sunrise schedule.
Files are on Github for those eager to learn more. [Jozerworx] also notes that getting started with the display is particularly easy with the inclusion of a setup mode. This allows the display to act as a Wi-Fi access point with a web page that you use enter your home Wi-Fi connection details.
We’ve featured a great many charming weather displays over the years, too. If you’re working to plot, chart, or even predict the weather—don’t hesitate to show us your cool projects over on the tipsline!
ESP32 EPaper Weather Station
7 thoughts on “Build Yourself A Graphing Weather Display
  1. NOAA provides pretty good free data feeds, courtesy of US taxpayers (me, for example).
    Obviously, they limit the fetches to that many per hour, but that’s all you need to know, and their API is relatively straightforward, with documentation and all.
    1. We use the NASA one for an application at work. It’s pretty straightforward: https://power.larc.nasa.gov/docs/tutorials/service-data-request/api/
      I don’t really have anything I’m proud enough to post as a project, but here is an example call that might be helpful: https://power.larc.nasa.gov/api/temporal/daily/point?parameters=T2M&start=20240101&end=20241001&community=RE&latitude=45.2&longitude=-76.1&format=JSON
      From there it’s pretty easy to substitute the parameters you want.
    2. Yep, I had two projects that needed something like twice-an-hour (quite slow by any means) weather lookups. I’ve thought about expanding and adding near stations’ feeds, too, so it can triangulate and make up precise spot weather, but that was over the board, nearest airport’s METARs and TAFs were good enough.
      Years and years back (I think 2012, maybe earlier) I’ve added automated adverse weather banner to one of the pages I was helping to rewrite, still there to this day, storm warnings fetched directly from the Mount Holly weather bureau feed. Good old NOAA, works when we need it to work.
      I also thought about hooking up some kind of Goodwill-bought $10 Weather Radio and transcribing the text, but never really went through, other projects had higher priority. If I’d pick up that thread, I’ll probably go for decoding SAME (targeted area alerts) as well.
  2. Keep in mind that this project was initially built for older version of Lilygo T5, which has 5 buttons and esp32 instead of esp32-s3. And it’s replaced with newer version, so you cannot buy it.
    Anyway, it’s quite doable to port this code but it requires some job to be done.
Leave a Reply to JaceCancel reply
