Weird Email Appliance Becomes AI Terminal
The Landel Mailbug was a weird little thing. It combined a keyboard and a simple text display, and was intended to be a low-distraction method for checking your email. [CiferTech] decided to repurpose it, though, turning it into an AI console instead.
The first job was to crack the device open and figure out how to interface with the keyboard. The design was conventional, so reading the rows and columns of the key matrix was a cinch. [CiferTech] used PCF8574 IO expanders to make it easy to read the matrix with an ESP32 microcontroller over I2C. The ESP32 is paired with a small audio output module to allow it to run a text-to-speech system, and a character display to replace the original from the Mailbug itself. It uses its WiFi connection to query the ChatGPT API. Thus, when the user enters a query, the ESP32 runs it by ChatGPT, and then displays the output on the screen while also speaking it aloud.
[CiferTech] notes the build was inspired by AI terminals in retro movies, though we’re not sure what specifically it might be referencing. In any case, it does look retro and it does let you speak to a computer being, of a sort, so the job has been done. Overall, though, the build shows that you can build something clean and functional just by reusing and interfacing a well-built commercial product.
Continue reading “Weird Email Appliance Becomes AI Terminal” →
This Week In Security: Hornet, Gogs, And Blinkenlights
Microsoft has published a patch-set for the Linux kernel, proposing the Hornet Linux Security Module (LSM). If you haven’t been keeping up with the kernel contributor scoreboard, Microsoft is #11 at time of writing and that might surprise you. The reality is that Microsoft’s biggest source of revenue is their cloud offering, and Azure is over half Linux, so Microsoft really is incentivized to make Linux better.
The Hornet LSM is all about more secure eBPF programs, which requires another aside: What is eBPF? First implemented in the Berkeley Packet Filter, it’s a virtual machine in the kernel, that allows executing programs in kernel space. It was quickly realized that this ability to run a script in kernel space was useful for far more than just filtering packets, and the extended Berkeley Packet Filter was born. eBPF is now used for load balancing, system auditing, security and intrusion detection, and lots more.
This unique ability to load scripts from user space into kernel space has made eBPF useful for malware and spyware applications, too. There is already a signature scheme to restrict eBPF programs, but Hornet allows for stricter checks and auditing. The patch is considered a Request For Comments (RFC), and points out that this existing protection may be subject to Time Of Check / Time Of Use (TOCTOU) attacks. It remains to be seen whether Hornet passes muster and lands in the upstream kernel. Continue reading “This Week In Security: Hornet, Gogs, And Blinkenlights” →
NASA May Have Lost The MAVEN Mars Orbiter
When the orbit of NASA’s Mars Atmosphere and Volatile EvolutioN (MAVEN) spacecraft took it behind the Red Planet on December 6th, ground controllers expected a temporary loss of signal (LoS). Unfortunately, the Deep Space Network hasn’t heard from the science orbiter since. Engineers are currently trying to troubleshoot this issue, but without a sign of life from the stricken spacecraft, there are precious few options.
As noted by [Stephen Clark] over at ArsTechnica this is a pretty big deal. Even though MAVEN was launched in November of 2013, it’s a spring chicken compared to the other Mars orbiters. The two other US orbiters: Mars Reconnaissance Orbiter (MRO) and Mars Odyssey, are significantly older by around a decade. Of the two ESA orbiters, Mars Express and ExoMars, the latter is fairly new (2016) and could at least be a partial backup for MAVEN’s communication relay functionality with the ground-based units, in particular the two active rovers. ExoMars has a less ideal orbit for large data transfers, which would hamper scientific research.
With neither the Chinese nor UAE orbiters capable of serving as a relay, this puts the burden on a potential replacement orbiter, such as the suggested Mars Telecommunications Orbiter, which was cancelled in 2005. Even if contact with MAVEN is restored, it would only have fuel for a few more years. This makes a replacement essential if we wish to keep doing ground-based science missions on Mars, as well as any potential manned missions.
Consider This Pocket Machine For Your IPhone Backups
What if you find yourself as an iPhone owner, desiring a local backup solution — no wireless tech involved, no sending off data to someone else’s server, just an automatic device-to-device file sync? Check out [Giovanni]’s ios-backup-machine project, a small Linux-powered device with an e-ink screen that backs up your iPhone whenever you plug the two together with a USB cable.
The system relies on libimobiledevice, and is written to make simple no-interaction automatic backups work seamlessly. The backup status is displayed on the e-ink screen, and at boot, it shows up owner’s information of your choice, say, a phone number — helpful if the device is ever lost. For preventing data loss, [Giovanni] recommends a small uninterruptible power supply, and the GitHub-described system is married to a PiSugar board, though you could go without or add a different one, for sure. Backups are encrypted through iPhone internal mechanisms, so while it appears you might not be able to dig into one, they are perfectly usable for restoring your device should it get corrupted or should you need to provision a new phone to replace the one you just lost.
Easy to set up, fully open, and straightforward to use — what’s not to like? Just put a few off-the-shelf boards together, print the case, and run the setup instructions, you’ll have a pocket backup machine ready to go. Now, if you’re considering this as a way to decrease your iTunes dependency, you might as well check out this nifty tool that helps you get out the metadata for the music you’ve bought on iTunes.
